I'm using m3u playlists because of their near universal compatibility, and simple format. My problem is that depending on where I access the m3u file from (it's stored on my file server) the path to the actual mp3 file varies.
My mp3s are all stored on a samba file server (soon to add nfs for linux clients). The share gets mounted as s: in windows. The files are stored under s:\mp3s\artist\album\01-track_name.mp3. I store m3u playlists under a separate directory called, imaginatively enough, playlists, i.e., s:\mp3s\playlists\my_favs.m3u.
When I save the m3u files under s:\mp3s\playlists\ the winamp (and foobar, too, it appears) sets an absolute path to the mp3 file as such:
S:\mp3s\Nine Inch Nails\The Downward Spiral\14 - Nine Inch Nails - Hurt.mp3
This breaks the playlist if I access it from a different computer that, say, doesn't mount the share as s:, but rather browses the network directly, like so:
\\Babylon\share\mp3s\Nine Inch Nails\The Downward Spiral
or if I'm accessing the mp3s from a linux client then the path would be like so:
/mnt/mp3s/Nine Inch Nails/The Downward Spiral/
etc.
So I need the mp3s to use relative paths--even if the mp3 is not in a subdirectory from where the playlist is saved. For example, if I edit the m3u playlist so that it reads:
..\Nine Inch Nails\The Downward Spiral\14 - Nine Inch Nails - Hurt.mp3
This works perfectly in all cases (most players in linux are happy with backslashes). the '..' climbs me back up into the mp3s directory so that I can descend back down into the artist/album/ directory.
Does anyone know of
(a) program that does this
(b) a way to make fubar do this
© a way to make winamp do this
