Topic: About CDRDAO (Read 4696 times) previous topic - next topic
About CDRDAO
How does CDRDAO work in the last EAC version?
About CDRDAO
Enable 'EAC Options' --> 'Write' --> 'Use CDRDAO for writing in the EAC layout editor'.  If you are having a problem with cdrdao, then you need to give some more details... -Martin.
About CDRDAO
What exactly is the purpose of CDRDAO in EAC?
About CDRDAO
to write CDs.
[span style='font-size:8pt;line-height:100%']edit: wow, a typo in no more than three words, I'm getting better ; )[/span]
Nothing but a Heartache - Since I found my Baby ;)
About CDRDAO
to write CDs.
[a href="index.php?act=findpost&pid=309403"][{POST_SNAPBACK}][/a]
CDRDAO should help those people who have problems burning CDs with EAC's internal engine. Also, you can do offset corrected burns with all writers and not only Teac (assuming your device supports overwriting the Lead I/O).
About CDRDAO
...Also, you can do offset corrected burns with all writers and not only Teac (assuming your device supports overwriting the Lead I/O).
[a href="index.php?act=findpost&pid=309411"][{POST_SNAPBACK}][/a]
You cannot overwrite with cdrdao... EAC's internal writing engine can only overwrite with a few Teac drives, but can write offset corrected with all drives supported... -Martin.
About CDRDAO
since cdrdao doesn't support overwriting
from this thread:
http://www.hydrogenaudio.org/forums/index....ST&f=20&t=34893
There's also a Plextor premium test in that thread, showing that it isn't possible to overwrite - neither with dao nor with the internal engine.
I know that I know nothing. But how can I then know that ?
