Topic: AAC vs MP4 (Read 8099 times) previous topic - next topic
AAC vs MP4
I have been looking into using a certain audio format for small clips hosted on a website. After testing out various codecs available, my personal preference goes to the AAC format.
Now my question is whether it would be better to use (raw) AAC or the MP4 container? I've read that the container should be better in the long run (compatibility). However since the clips will be available on a public website it has to be possible to play them with the bigger players around. I could be doing something wrong, but my WinAmp does play the AAC file, but not the MP4.
For encoding I have been using the Nero Frontend, which allows the end user to choose between the AAC and MP4 format.
AAC vs MP4
Winamp should be abel to play AAC with MP4 container. Perhaps your Winamp need's to be updated or something. I would suggest using the MP4/M4A container.
AAC vs MP4
If you use HE-AAC, I think Winamp's MP4 support is broken for that (there are plugins that fix it). But for normal LC-AAC, yes, MP4 should work even with Winamp...
AAC vs MP4
Winamp 5.03 supposts mp4 playback
All big players (newer version) support mp4 by default......except M$ Windows Media Player
AAC vs MP4
M$ Windows Media Player will play mp4 or aac,
if u install mp4 parser, directshow aac decoder and aac parser,
because it's a dshow based player :)
AAC vs MP4
[a href="index.php?act=findpost&pid=294821"][{POST_SNAPBACK}][/a]
Just noticed Winamp 5.0.9 got released. The support for HE-AAC MP4 files is still fuxored.
AAC vs MP4
This may be offtopic, but if you are concerned about compatibility you should use MP3 instead of AAC/MP4, IMO.
MP3 is compatible with everything out of the box.
