Topic: DVD Audio or SACD ? (Read 64884 times) previous topic - next topic
DVD Audio or SACD ?
Hello everyone,
A lot of audiophiles approves the SACD formats, but some irreducible retorts that the DVD Audio is superior.
And you, of what side are you?
DVD Audio or SACD ?
Garf's sig say's it all...
The answer to the SACD vs. DVD-Audio question is: CD -- DigitalMan
flac > schiit modi > schiit magni > hd650
DVD Audio or SACD ?
Please search and read the FAQ - this has been discussed many, many times here and I don't think another discussion would achieve anything.
DVD Audio or SACD ?
Sorry, I didn't know it.
DVD Audio or SACD ?
If it helps, I believe there are now hardware players that support both formats.
DVD Audio or SACD ?
Thank you indybrett, but I know this domain very well.
Ayre, Linn, Méridian already develops for a long time this principle.
I wanted to know that rightly that uses each among us.
DVD Audio or SACD ?
In my opinion, the only way to answer this is to perform blind comparisons. And to be sure that both tracks are coming from the same mastering. It seems that nobody did it.
DVD Audio or SACD ?
I approve your reasoning on the principle of this comparison.
But what to say formats audios that constitutes the world of music.
Must one to trust the decoders audios, that identifies and read the formats ( on PC) or to electronics (sources, readers DVD or SACD of lounge) that treat it also.
DVD Audio or SACD ?
My sig says another thing about that discussion, actually, from one of the foremost experts here
Personally I strongly favor DVD-A over SACD/DSD on technical grounds. This has been elaborately discussed here before.
Read for example http://sjeng.org/ftp/SACD.pdf
Favorite quote:
Finally, consider 8-bit, four-times-oversampled PCM with
noise shaping. This is also a data rate one-half that of DSD and
double that of CD, with a sampling rate of 4 × 44,100 =
176,400 Hz. It can achieve a noise floor 120 dB below full
scale up to 20 kHz, using 96 dB of noise shaping, and a total
noise power of –19 dBFS. Its frequency response would be
flat to 80 kHz. This example is perhaps the most instructive of
the lot. For a data rate one-half that of DSD, it achieves a
comparable signal bandwidth, with a similar noise power
density up to 20 kHz, but much lower power above this
frequency, and 28 dB lower total noise power. It is fully
TPDF-dithered, and so is completely artefact free. At one-half
the data rate it outperforms DSD on every count! DSD is a
profligate wastrel of capacity.
DVD Audio or SACD ?
Good evening Garf,
Would the quality of a product be bound only to a technical proof?
I don't think it.
It is only my opinion: my ears first then the view.
What I know, an amplifier transistor will never be an  lamp amplifier and even less a hybrid amplifier.
The comparison will always be uncertain and function of the individual's entity.
DVD Audio or SACD ?
I Would Recommend DVD-A
DVD Audio or SACD ?
What part of
At one-half the data rate it outperforms DSD on every count!
didn't you understand?
The goal of the carrier is to reproduce the original signal as faithfully as possible. DSD is very suboptimal in that regard. That's a mathematical fact.
Distortion (like the one from your beloved tube amps) can (and should!) always be added later on, since it's entirely subjective what sounds "better" there.
DVD Audio or SACD ?
I admire the clarity of your speech because you give proof on the one hand of truth.
Long life to the développemnt of your codec audio.
To soon
DVD Audio or SACD ?
[a href="index.php?act=findpost&pid=276521"][{POST_SNAPBACK}][/a]
[span style='font-size:8pt;line-height:100%']emphasis is mine[/span]
I don't know if this is even possible since the processing of DSD and PCM data is so different.
Right now SACD are mostly created from 96/24 masters (at best) and surely the converted DSD signal can not be better.
DVD Audio or SACD ?
DVD-A !!
SONY has to be punished for their constant attempts to establish their own 'standards', with us, the users, being the ones paying the bills  ...
DVD Audio or SACD ?
What's all this talk about optical carriers about? Don't you know that is sooo 20th century...
DVD Audio or SACD ?
[a href="index.php?act=findpost&pid=276770"][{POST_SNAPBACK}][/a]
You would have to know, that many electrical and electronic engineers are not in agreement with this.
In many cases this is a market opinion, and it does not reflect the exact reality...
DVD Audio or SACD ?
[a href="index.php?act=findpost&pid=276142"][{POST_SNAPBACK}][/a]
I doubt much that, due to the limitations of the human ear, you notice a difference between SACD, Dvd-a, and Audio CD (for normal stereo listening).
of course, if you notice differences this probably is as consequence of differents masterings...
DVD Audio or SACD ?
Hello Acid Orange Juice,
"You would have to know, that many electrical and electronic engineers are not in agreement with this.
In many cases this is a market opinion, and it does not reflect the exact reality... "
Indeed, if you take the example of the very upscale: Naim Nac552/Nap500, Meridian, Dcs elgar, Ayre or Linn, it is true the analysis of the specter, the passing strip and the dynamics is not really the same.
But the charm of the tube (artisanal manufacture) will remain and will give a heat always little present among the big constructors of electronic high-quality.
" of course, if you notice differences this probably is as consequence of differents masterings... "
The mastering is often questioned in this case of face.
Must i think that an excelllent mastering of the SACD can surpassed a DVD Audio of middle quality.
Finally, this analysis makes myself think about the eternal return (psychoanalysis): the mobile picture of one immobile eternity.
It is strange, but that reflects there strongly: Mastering/Quality, Quality/Mastering.
DVD Audio or SACD ?
Heh. An excellent mastering on CD has probably nothing to envy to any SACD or DVD-A.
And, again, technically, DVD-A is far superior to SACD. The point is if that makes DVD-A sound any better than SACD. But then, even when both are technically better than redbook CD, it's not clear that this can make them sound any better than good old CD. It's all about mastering.
DVD Audio or SACD ?
The key advantage to SACD is that it can easily be distributed as a hybrid CD. I haven't seen any listening-test being conducted that clearly favored one over the other, so unless the music is targeted at bats, I think the world would be better off with SACD becoming the standard.
Just my 2¢.
DVD Audio or SACD ?
DVD-A !!
[a href="index.php?act=findpost&pid=277193"][{POST_SNAPBACK}][/a]
What bills?
DVD Audio or SACD ?
Hello guada2  ;
My opinions are based in my own experience as electronic engineer and as scientist; not by publicity or by opinions of third parts, that, others repeat like parrots without having idea of the subject which they are treating.
Their arguments are not more than their own and subjective opinions, and they are not based on facts, evidence or science; like either in engineering.
I have 4 years designing amplifiers of high fidelity. If you think that you will obtain better quality with an expensive amplifier of tubes, when you can obtain the same sound with an amplifier of transistors well designed (by a much smaller cost), then, you are free to waste your money...
... again ...
Your opinions are not based on facts or scientific evidence; they are based only in magical suppositions..
you did not pay attention to this:
It's a fact, not a supposition..
It's well known that the audio CD is completely overkill for the human ear. The normal audio CD have more resolution that the human ear is able to perceive. SACD and DVD-A have more resolution that the normal audio CD.. but.. for what?. It's not necessary for your ears.. maybe if you are a dog probably you hear the difference...
Of course, this is for the case of normal stereo listening.. For multichannel is another story..
DVD Audio or SACD ?
To see if there are indeed audible differences between DVD-A and CD, would a valid test be to make a recording @ 96khz/24 bit WAV (a dvd-a spec), resample to a 44.1khz 16 bit CD spec WAV, and ABX the two, or would the 96khz recording be invalid because it wasnt first compressed in the DVD-A MLP format? Would differences become apparent through dithering noise?
DVD Audio or SACD ?
"Their arguments are not more than their own subjective and expressed an opinion, and they are not based one facts, evidence however science; like either in engineering.
I haggard 4 years designing amplifiers of high fidelity. Yew you think that you will obtain better quality with year expensive to amplify of tubes, when you can obtain the same sound with year to amplify of transistors well designed (by has much smaller cost), then, you are free to waste your money... "
I don't put in doubt your experience, But to think that one DCS ELgar Plus/Verdi/Purcell doesn't make the weight, I am not sure. In short, it was only a parenthesis.
Indeed, I join you on a point: these are not the best electronic that pull the best resonant restitution. Because you know it all as much than me, that the quality of a source raises several criterias of tests.
After some years of comparatives and purchases of materials, I resolved to this stereo system:
Source: Linn Ikemi
Integrated amp: Icos Elsberg 270
New loudspeakers: Thiel CS2.4
Case of alimentaion sector: MPC
Cables HP: Synergistic Research
Cables of modulation: Esprit
It is not the dearest, but I am pleased of its capacity to answer best to the system that I searched for.
For what concerns video I reserve the right of all disclosure: scaler + spotlight + player DVD + préamp + amplifier multicannal + loudspeakers 5.1.
