Topic: Toaster for Fb2k (Read 322405 times) previous topic - next topic
Toaster for Fb2k
Reply #200
is there a website that has some skins for this?
Toaster for Fb2k
Reply #201
Is there anyway to set a hot key to display the song playing?
Toaster for Fb2k
Reply #202
[a href="index.php?act=findpost&pid=315469"][{POST_SNAPBACK}][/a]
you can set a hotkey to show a toast by:
1. Preferences > Core > Keyboard Shortcuts
2. Under "Actions" navigate to [main] Components/Toaster/Show Toast
3. Put the key combo in the box, check if you want it to be global, and click "Add"
Toaster for Fb2k
Reply #203
[a href="index.php?act=findpost&pid=315486"][{POST_SNAPBACK}][/a]
Thanks :D
Toaster for Fb2k
Reply #204
Tab "Covers"
"Use folder images" don't support "*" ?
or i have other problem
i use
Toaster for Fb2k
Reply #205
shaneh,
This is an excellent plugin - I used with WinAmp before I discovered foobar.
I have a feature request - would it be possible to "animate out" when the mouse moves over the toast  ?  When the mouse moves away, then "animate in" ?
I keep my toast on permanently so this would be really handy.
If you already have this in your plethora of options, then hit me.
c0utta
Toaster for Fb2k
Reply #206
shaneh,
c0utta
[a href="index.php?act=findpost&pid=322299"][{POST_SNAPBACK}][/a]
Seconded.
Toaster for Fb2k
Reply #207
For some reason, Toaster no longer wants to let me configure it. It pops up the default blood-red-middle-of-screen toaster display, and no configuration is possible via components menu or the prefrences dialog.
Toaster for Fb2k
Reply #208
shaneh,
c0utta
Seconded.
[a href="index.php?act=findpost&pid=322306"][{POST_SNAPBACK}][/a]
Same Problem here
When import toaster it works but when i close and run  fobbar appear the red(defaut) toastar
Toaster for Fb2k
Reply #209
It's the same problem with me - it's caused by non-english characters in the Documents And Settings/user/Application Data/foobar2000 directory (I, for instance have Data Aplikací instead of Application Data) and toaster cannot handle that.
However there was no update for quite a while, so I eventually switched to foo_prettypop which is not as good as toaster, but what can I do...
Toaster for Fb2k
Reply #210
Guess ill use individual and not user based configuration then.. no biggie, i only use one user anyway.
Toaster for Fb2k
Reply #211
I can't get the custom skin and album art/info to line up.  Any help?
Toaster for Fb2k
Reply #212
Well, no go for me. Still cant see toaster's configuration page at all, no matter which user-based option i chose at the install.
Toaster for Fb2k
Reply #213
Hey ChaosBladE,
I also had this issue and had to use "Preferences-Core-Main Menu Items" and then add the command "Components/Toaster/Configure Toaster".
A pain in the backside, but at least you can now access it from the Components menu.
c0utta
Toaster for Fb2k
Reply #214
I feel pretty stupid right now. Should have thought of that XD
Thanks, c0utta, It works well enough.
Toaster for Fb2k
Reply #215
hi,
wanted to know the exact same thing - only don't have toaster in the keyboard shortcut section, even though it appears under the components list ..?
also, for some reason, the cover art just won't show on the toaster popup - even though it works fine with the exact same config used successfully in winamp ..?
if anyone could help me on these two issue, that would be great ..!
cheers ..
Toaster for Fb2k
Reply #216
Hi.
First off, thank you, shaneh, for your excellent work. This plugin is great! I hope you continue this project...
...which comes to my question, a question that was asked many times before in this topic - could you add the support for the *.jpgs? Preety much of my collection has got covers from Amazon (which is for example B00004C4L3.01._SCLZZZZZZZ_.jpg) or from other sources. Plus, I don't want to rename them, because I have the most of them on my CDs (= I'd had to reburn them). As I've read, you've coded this for Winamp. Is it possible for this to do it in fb2k?
Thanks in advance for your response.
Toaster for Fb2k
Reply #217
[a href="index.php?act=findpost&pid=331057"][{POST_SNAPBACK}][/a]
So, you like the Clash
Toaster for Fb2k
Reply #218
You just had to look that up?
Toaster for Fb2k
Reply #219
I've added the plug-in to my components folder, but its not appearing in my component list in Preferences...
Am I missing something really obvious?
Toaster for Fb2k
Reply #220
[a href="index.php?act=findpost&pid=332548"][{POST_SNAPBACK}][/a]
Components > Toaster >  Configure Toaster
Toaster for Fb2k
Reply #221
It might not be there, though. Make sure you check the options for the menu context options, and add it back to the components menu if it isnt there.
Toaster for Fb2k
Reply #222
Oh, sorry I thought you meant it was meant to be in the components section of the Preferneces. It's right there in the "components toolbar"!
Toaster for Fb2k
Reply #223
Try this one I've made recently
With cover art
Without cover art
My English sucks... Forgive me :(
Toaster for Fb2k
Reply #224
With cover art
[a href="http://img416.imageshack.us/my.php?image=foobar018fl.jpg" target="_blank"]
