Topic: Ape Files On Windows Media Player (Read 10950 times) previous topic - next topic
Hi, I recently started using Windows Media Player(as well as Foobar),  after reading some info on this site.
I've been having a listen to WMA Lossless Compression. The only problem I've had is that my whole music collection can not be played on WMP, as it doesn't support Ape Files or MPC. Does anyone know if there are any downloadable plugins, so I can play these formats?
Thanks in anticipation.
Osmar
Check this out too:
MonkeySource_v1.00
http://dsp-worx.de/index.php?n=7
The DS Monkey Audio Filter is a simple Filesource Filter that uses MACDll.dll (since Version 0.50 it´s renamed to MACDec.dll because of Unicode Filenames) to decode .ape Files. With it you're able to play Monkey Audio Files from any DirectShow based Player, like Windows Media Player, Zoomplayer, MPC and TCMP. The Filter supports Unicode Filenames on every Windows OS, can read APEv2 Tags and is able to play .apl Playlists.
