Topic: -q0 in Ogg v1.0 different than RC3/4? (Read 3303 times) previous topic - next topic
I just started listening and testing Ogg Vorbis (1.0) so have no experience with earlier versions like RC3 or even 4.
The only problem I have is that I am confused. I personally think -q0 sounds amazing where I only read bad report of -q0. These posts obviously stem from RC3 or 4 tests (I think) but am not sure.
So the question is: did -q0 (and up) change that much from the release candidates or should I go to the doctor to have my hearing tested?
On the side: I _do_ hear the problems in general (CBR) MP3 @128kb/s so I use LAME @ ~170 VBR. I hear _nothing_ that disturbes me in Ogg -q0!
Testing is done by extracting the compressed files back to raw audio and burn that to a generic audio CD and listen to that on my fairly good quality stereo setup.
I know it's not an ABX test, but who cares if I don't even hear the difference when I KNOW what I listen to?
Martin
As a simple answer, yes, there are very significant quality improvements in the 1.0 low q settings compared to RC3 and other pre 1.0 versions.
yes... it has been muchly improved at low bitrates, but at q0 it doesn't come close to the qualty of a 170VBR mp3. :eek:
Ok, I must admit I've been a little uncarefull in my early conclusions about -q0.
I do hear artefacts at this quality setting, but they are very different from MP3@128 (the well known running of a brook in the highs).
That's why I thought -q0 was so good (and I still think it is!)
Now I guess I will stick to -q1 (a small step for man...) which is, sorry to tell _nearly_ indistinguishable from CD for me (or at least as good as Lame @ ~160vbr). Except for 1 classical piece I encoded, and even then I can only ABX it maybe for one very small typical part in the beginning.
No need to say I'm utterly impressed with Ogg and if it weren't for my portable I would have switched completely by now!
Martin
