Topic: XviD 1.0.1 first bugfix release (Read 3856 times) previous topic - next topic
Monday, 07.06.2004 07:10h MET
The first bugfix release, XviD-1.0.1, is available. All bugs are really minor, even if the bug descriptions sound bad. Enjoy!
Latest binaryXviD-1.0.1-05062004.exe (617kb)
Changelog:
- (core) small trellis bug which probably reduced sharpness of the image, but possibly even produced artifacts
- (core) motion estimation buglet slightly reduced b-frame's quality
- (core) 1 fps files failed to decode
- (core) intra coefficients were sometimes not clipped correctly, which might (in theory) produce artifacts (don't worry, noone has seen the artifacts yet)
- (core) if two p-frames were more than one second apart, b-frames in between are not decoded
- (VfW) video was not playable via ICM (mplay32.exe, files embedded in Office applications etc)
- (VfW) calculator did not open many useful audio/subs extensions by default
- (VfW) calculator calculated audio size wrong when given bitrate and length (2.4% error)
source: http://www.xvid.org
Download: http://www.koepi.org
Hong Kong - International Joke Center (after 1997-06-30)
