Topic: Dark Side of the Moon MFSL Sound Clip (Read 17430 times) previous topic - next topic
Here's a 30 second sample from MFSL Original Master Dark Side of the Moon (UDCD 517).  It's the first 30 seconds of the song, "Money."
And for comparison....the EMI 1992 remaster - "CDP 7 46001 2 DIDX 226" and "7777-46001-2"
Apparently this version is the "Twentieth anniversary remaster". Not the SACD red book layer....anyone who owns that, please upload it!
Perhaps not the most complex portion of the song has been chosen
Here's a bit more complex sample from (the third song) "Time" at 2:30 to 3:00 in the song.
And finally, a portion of the last song, "Eclipse" from 1:00 to 1:30.
I would really appreciate it if anyone with the SACD version of this album would upload at least one of these samples...
Thanks Sebastian!
This is Eclipse.
And this is the log:
EAC extraction logfile from 1. June 2004, 0:25 for CD
Pink Floyd / The Dark Side Of The Moon
Used drive  : HL-DT-STDVD-ROM GDR8162B   Adapter: 0  ID: 1
Read mode   : Secure with NO C2, accurate stream, disable cache
Read offset correction : 102
Overread into Lead-In and Lead-Out : No
Used output format : C:\Program Files\Monkey's Audio\wapet.exe   (User Defined Encoder)
                     320 kBit/s
                     Additional command line options : %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" mac.exe %s %d -c4000
Other options      :
    Delete leading and trailing silent blocks : No
    Installed external ASPI interface
Range status and errors
Selected range
     Filename C:\Documents and Settings\Administrator\Desktop\Time.wav
     Peak level 88.2 %
     Range quality 100.0 %
     CRC 9FEC1EAC
     Copy OK
No errors occured
End of status report
EAC extraction logfile from 1. June 2004, 0:27 for CD
                     320 kBit/s
Other options      :
Selected range
     Filename C:\Documents and Settings\Administrator\Desktop\Eclipse.wav
     Peak level 100.0 %
     CRC 0AF58129
     Copy OK
No errors occured
Could you please upload "Money" 4:30 - 5:00 from the MFSL original master Dark Side Of The Moon? I uploaded my SACD version.
EAC extraction logfile from 1. June 2004, 0:42 for CD
                     320 kBit/s
Other options      :
Selected range
     Filename C:\Documents and Settings\Administrator\Desktop\Money.wav
     Peak level 100.0 %
     CRC B9E46F63
     Copy OK
No errors occured
Just in case someone needs it...
CD: 7-24358-21362-1
ISRC of "Time": GBAYE0300337
ISRC of "Money": GBAYE0300339
ISRC of "Eclipse": GBAYE0300343
Edit : no more than 30 seconds of the same song, please. (30 other seconds are already posted).
Finally, the first 30 seconds of "Money" (SACD).
EAC extraction logfile from 1. June 2004, 0:55 for CD
                     320 kBit/s
Other options      :
Selected range
     Peak level 92.6 %
     CRC B804B0C5
     Copy OK
No errors occured
Edit: Attachment removed. A new sample has been posted below.
We'll have to wait for ChangFest for the MFSL version of this segment....
Edit : no more than 30 seconds of the same song please (30 other seconds were already posted).
Whoop! Sorry Pio!
For first 30 seconds of Money is there only volume difference or something else (or it is my imagination to hear something else...)?
Edit: There's some background tone in MFSL version exists (AND noise, of course)
Sounds about right to me, I plan on decoding and probably replay or wavegaining (I know!) the samples to give a level playing field....
Here's the MFSL version of this clip:
MFSL version:
Is there also a conclusion or a summary of the quality and/or taste of these samples?
For those who are interested, I have "Eclipse" ready to post (if I know how) the stereo SACD layer from the 30th Anniversary Edition (EMI 2003). Also the last 30 seconds by the way, the same as posted before as MFSL, EMI 1992 and the RedBook layer of the SACD. Not a digital copy of coarse, but an analog captured with a stand alone CD-Recordable.
Regards,
Jacco
Logical reasoning brings you from a to b, imagination brings you everywhere.
Go ahead.
Here's the same segment of Time from the CD layer of the SACD release. Personally, I think the MFSL sounds the best compared to this and other CD releases. I think it's about tied with the SACD layer.
analog transfer of 3:30-4:00 of Money from the SACD layer
[attachment=4570:attachment]
analog transfer of 2:30-3:00 of Time from the SACD layer
[attachment=4571:attachment]
analog transfer of 1:00-1:30 of Eclipse from the SACD layer
[attachment=4572:attachment]
I did these quite awhile ago, but IIRC the SACD layer was output from an oppo970, into an M-audio 2496, at 88.2Khz/24 bit, then split into tracks and converted to redbook, all using Audition.
