Topic: mp3 surround (Read 15697 times) previous topic - next topic
mp3 surround
Besides, it has already been pointed out that this is no "evolution", multichannel MP3 has been standardized (as MPEG2 audio BC) since MPEG2 was standardized.
mp3 surround
OK. Sorry, I'm short in time - performed a little search in the forum, without success. I've just saw this new on a french website. I'm also aware about multichannel abilities of mp3, and I wondered about the possible differences between standard mp3 and the Fhg evolution.
This topic should be deleted, or closed. My apologizes.
Wavpack Hybrid -c4hx6
mp3 surround
I know that this topic is very old
but there is definately a news about mp3 surround.
Check
http://www.cdfreaks.com/news/11005
There is a Mp3 Surround that is just come into existance.
the files have a .mp3 extension.
Check out (article dated November 30, 2004)
http://www.iis.fraunhofer.de/amm/download/...termsofuse.html
for mp3 surround Encoder,Decoder,Winamp Plugin and sample downloads.
Please guys check it out its MP3 Surround.
Do let me know whether this is something new or that is the same old stuff.
mp3 surround
As Gabriel already mentioned, this is not multichannel, but surround mp3s.
I think, it is the same as Spatial audio (i.e. Spatial audio attached to mp3) but I can be wrong...
mp3 surround
[{POST_SNAPBACK}][/a]
Is the software new? Yes. Is the news new? No, see the [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=29766&]Software thread[/url]. Is the idea new? No, read the posts above!
"Facts do not cease to exist just because they are ignored."
—Aldous Huxley
mp3 surround
@SirGrey it has to be multichannel
because they provide a 5.1 wav sample for encoding purpose.
Did you give it a try because it show as 2 channel mp3 in winamp and foobar
properties.
i dont have 5.1 speakers can some one try out the samples at there site
and let us know whether they are really 5.1
while playing the file in mp3surround player the progress bar moves and time is
displayed but no audio is heard.
mp3 surround
There is a big difference between multichannel (i.e. sound that consist of N discrete(at least partially) channels and surround, which means restouration of N chanels from M channels that we already have.
Do you call a Dolby Surround a multichannel ?
If yes, then from this point of view mp3 surround is multichannel too...
mp3 surround
i am really confused
please test the samples and let me know
thanks in advance.
mp3 surround
Download this PDF it clarly specifies MP3 Surround has 5.1 capabilities
Link:-  http://www.iis.fraunhofer.de/amm/download/mp3_surround.pdf
Software package
This package contains the following software:
MP3 Surround Commandline Encoder:
%InstallDir%\mp3sCmdlEnc.exe
MP3 Surround Graphical Encoder:
%InstallDir%\mp3sDropEnc.exe
MP3 Surround Commandline Decoder:
%InstallDir%\mp3sDecoder.exe
MP3 Surround Realtime Player:
%InstallDir%\mp3sPlayer.exe
MP3 Surround Decoder Dynamic Link Library (dll):
%InstallDir%\mp3sDecDLL.dll
MP3 Surround Development Kit (SDK):
in %InstallDir%\Developer\
MP3 Surround Winamp Plugin (experimental):
in %InstallDir%\Goodies\in_mp3s.dll
Readme for MP3 Surround Winamp Plugin (experimental):
in %InstallDir%\Goodies\readme_winamp.txt
the "mp3scmdlenc.exe" takes following arguments
Usage: mp3sEncoder.exe Input.wav Output.mp3
Input.wav:
       This has to be a regular or extensible six channel wave file,
       with following channel sequence:
       Left, Right, Center, LFE, Left Surround, Right Surround.
Output.mp3:
       The destination MP3 Surround file name.
some more info
It converts 5.1 channel '.wav'-files to MP3 Surround files.
Features:
    - 16 or 24 bit resolution.
    - 44.1 or 48 kHz sampling rate.
    - Standard wave-format or wave-format extensible.
    - Runs at a total constant bitrate of 192 kbit/s.
Note:
For both formats (standard wave and wave extensible) the channels
have to be interleaved and in the order:
Left Front, Right Front, Center, LFE, Left Surround, Right Surround
The MP3 Surround Encoder does not accept 5.1 channel '.wav'-files
that carry a stereo signal only.
Usage:
In a Windows Command shell type:
mp3sEncoder.exe input.wav output.mp3
to convert input.wav to output.mp3
MP3 Surround files can be played in stereo on any
standard MP3 player or software.
The MP3 Surround Graphical Encoder has the same features and restrictions
as the MP3 Surround Commandline Encoder.
Additionally the MP3 Surround Graphical Encoder supports Multi-File-Encoding.
Usage:
Drag and Drop a selection of 5.1 channel '.wav'-files on the
MP3 Surround Graphical Encoder.
Note:
To increase the encoding speed you can disable the rotating animation by
pressing the right mouse key and selecting 'Disable Animation' in the context menu.
It converts MP3 Surround files to 5.1 channel '.wav'-Files.
Features:
    - Writes 5.1 standard wave-format files
    - 16 bit resolution
Note:
The channels are interleaved and in the order:
Usage:
mp3sDecoder.exe output.mp3 output.wav
to convert output.mp3 to output.wav
The MP3 Surround Decoder produces always six channels.
If the files are 'normal' MP3 files without surround extension,
only 2 of the 5.1 output channels contain the audio signal
and additionally four empty channels are added.
It plays MP3 Surround files and standard MP3 stereo files on
your multichannel soundcard.
Start mp3sPlayer and open an MP3 (Surround) file or just
drag it onto the player window.
Make sure:
    - Direct X Version 9.0 or greater is installed
    - A 5.1 capable soundcard is installed and 5.1 speakers are connected
    - The speaker settings are set to '5.1 Surround Sound'
For information how to set the speaker settings use the Windows Help Center.
If the player detects an MP3 Surround file, the 5.1 reproduction
starts automatically. Toggling the '5.1 button' switches between stereo
and 5.1 surround sound.
For standard stereo MP3 files this button is deactivated.
MP3 Surround Decoder SDK
Following files are included in the Software Developer Kit:
    - %InstallDir%\Developer\make\mp3sDecDemo.dsp
   The MSVC++ 6.0 project file for building an
   MP3 Surround command line decoder.
    - %InstallDir%\Developer\include\mp3sDeclib.h
   Header file for the MP3 Surround library
    - %InstallDir%\Developer\source\demo.c
   Example source code, that demonstrates how to implement
   the MP3 Surround Decoder Library
    - %InstallDir%\Developer\lib\mp3sDecDLL.lib
   MP3 Surround Decoder import library. Contains information
   about the used symbols in mp3sDecDLL.dll
    - %InstallDir%\Developer\Documentation\mp3sdec-interface.pdf
   The MP3 Surround Decoder interface description
The required MP3 Surround Decoder Dynamic Link Library (dll) mp3sDecDLL.dll
can be found in %InstallDir%.
Note: The compiled version of demo.c hase the same functionality as the
      mp3sDecoder.exe.
The MP3 Surround Winamp Plugin can be found in
Please follow the installation instructions in
to find out, how it is integrated and enabled in your Winamp installation.
MP3 Surround Encoder Restrictions
    - Accepts 5.1 channel '.wav'-files only.
    - Always runs at a total constant bitrate of 192 kbps.
    - Input files must either have 44.1 kHz or 48 kHz sampling frequency.
    - Does not accept 5.1 channel '.wav'-files that carry a stereo signal only.
The MP3 Surround Encoder expires on the 31st of December 2005.
This is all the give info in "readme.txt"
mp3 surround
[a href="index.php?act=findpost&pid=258444"][{POST_SNAPBACK}][/a]
I call stereo "multichannel" - unless one of my speakers isn't working!
Sorry - couldn't resist. You're trying to put fixed meanings onto words which aren't that specific or accurate or even meaningful!
David.
mp3 surround
Of cource I ment "multichannel" -> channels > 1 ))
