Topic: Encoding at "low" priority. (Read 3417 times) previous topic - next topic
Sorry for the blatent cross post, but I figured you guys would probably know more about this stuff. Basicly, I would like to use EAC to encode files, but each time the encoder runs I would like it to run as "low" priority. Check out the thread below if you wanna know all the stuff I have tried so far. I'm out of ideas here. Thanks.
http://arstechnica.infopop.net/OpenTopic/p...16&m=4240935885
so set it to low priority.
Lol. Arstechnica are arstechnica indeed.
Open EAC (doh), go to Menu 'EAC' > 'EAC Options' > 'Extraction' Tab.
Set 'Extraction and compression priority' to 'Idle'.
Forgive me if this is something you've already tried (didn't see it explicitly mentioned here or in the other thread).
EAC menu bar...
EAC --> EAC Options --> Extraction tab --> Extraction and Compression Priority -> Idle
Unless I'm mistaken, this would only use CPU cycles if your machine is not doing other processing.  As for setting it somewhere between "Idle" and "Normal", that I don't know how to do right off hand.
Edit: Damn!  Too slow I am, and by six minutes no less!
I knew I should have just posted over here first. All this messing with batch files and there was an option in EAC the whole time.
