Topic: can I removed suggested ununsed tags fields? (Read 1198 times) previous topic - next topic
Hi
i have tried some tests , just adding new field like fav , favorite and mood
but just because i wanted to perform some tests
now , even i removed from the file these fields and i have "reload info from files" , they are still presents
is there a way to remove from foobar?
i'm using foobar 2.1.5 32bit portable
thanks
screenshot
Re: can I removed suggested ununsed tags fields?
File->Preferences->Advanced->Display->Properties dialog->Field name suggestions
hi
 have I to remove manually or is there a checkbox to disable them?
thanks
hi
thanks
If you click on them they all get selected at once and so can all be deleted at one go.  If you want to keep some, then you have to pick through it manually.  Or, you could copy them when they're all selected, paste the list elsewhere to be returned or edited when needed, THEN delete the whole go.  BTW, if you had actually looked at the setting Bogozo pointed out you could SEE there is no "checkbox."
hi
thanks
hi @sveakul @Bogozo
i was thinking it was this checkbox
screenshot
in the first screenshot , where there are red arrows , i tried to delete them from the menu Fav and Favorite ,with the keyboard canc or delete but nothing
in short i have delete from this screenshot
screenshot
sorry for my poor english
best regards
