Topic: FLAC encoder for arm cortex m4f with limited memory (Read 6154 times) previous topic - next topic
Hi
I have an application that would benefit from FLAC encoding (realtime microphone-to-sd-card recording).  However the microcontroller is a 100 MHz arm cortex m4f, and the memory size is not quite enough for FLAC encoding according to the official spec.  Is there a slightly lower-performance FLAC encoder with a smaller memory footprint ?
Bob
Re: FLAC encoder for arm cortex m4f with limited memory
There are a lot of FLAC decoders available, but only a few encoders.
How have you tried to get the reference encoder working? It is possible to strip quite a lot of parts, maybe that way it'll fit? Stripping the floating point parts is going to save a lot of memory for example.
Unless your tied to FLAC, WavPack might work for you. I created a tiny encoder a long time ago that should still be usable. It's used in Rockbox to this day (in fact I may have created it for that application) and encodes CD quality on far slower ARM processors than yours.
If that's still too much (the tiny encoder uses about 100 KBytes or so for code and data) I created another lossless compressor called SLAC that is very lightweight. The disadvantage of that is the files are not compatible with anything (there's not even really a file format, per se) but depending on your application that might not be an issue (it's lossless, so conversion could be done later off your device to something universal).
Will it load so much into memory if invoked with -l0 -ss?
And how about your gloriously future-proof MS-DOS version?  ;)
Thanks for the advice, I’ll look into all this.  Where might I find the ms-dos version?
https://hydrogenaud.io/index.php/topic,123374.0.html
Edit: looking at that thread, I don't see any particular reason it should be any better or worse. There was some discussion on what had to be done to get it compatible with even older CPUs, but that was a hypothetical thing, I remembered wrong.
I mean, how little memory we talking? Smaller frame sizes means less data to work with at a time, that could help.
I don't think using a retro MSDOS version as a starting point makes any sense when standard FLAC is already meant to run on embedded devices.
How little memory are you looking to use?
