Topic: ASIO output seekbar wiggles backwards and forwards when paused. (Read 506 times) previous topic - next topic
I'm using ASIO output with my Topping DAC and have noticed that when pausing a song the seekbar and Waveform Minibar (mod) will keep wiggling backwards and forwards. Sometimes it takes a few pauses to get the seekbar to "wiggle" but it tends to trigger more often than not. Changing the seekbar position while it paused and wiggling will stabilise the seekbar. Outside of the wiggling there doesn't seem to be any impact on playback.
I've attached a screen capture showing the issue.
Core (2024-05-01 16:32:20 UTC)
    foobar2000 core 2.2 preview 2024-05-01
foo_benchmark (2018-07-18 20:55:48 UTC)
    Decoding Speed Test 1.2.5
foo_bitcompare (2022-11-09 00:13:02 UTC)
    Binary Comparator 2.3.2
foo_converter (2024-05-01 16:32:50 UTC)
    Converter 2.2 preview 2024-05-01
foo_convolve (2019-12-15 21:18:58 UTC)
    Impulse Response Convolver 0.3.3
foo_cover_utils (2024-03-02 16:17:22 UTC)
    Cover Utils 1.0
foo_dop (2020-02-02 17:28:14 UTC)
    iPod manager 0.7.2
foo_dsp_effect (2024-03-31 15:27:18 UTC)
    Effect DSP 0.50
foo_dsp_eq (2024-05-01 16:32:54 UTC)
    Equalizer 1.2.3
foo_dsp_meiercf (2018-01-06 10:27:18 UTC)
    Meier Crossfeed 1.1.1
foo_dsp_src_resampler (2023-03-16 01:05:56 UTC)
    SRC Resampler 1.0.14
foo_dsp_std (2024-05-01 16:32:56 UTC)
    Standard DSP Array 2.2 preview 2024-05-01
foo_facets (2011-08-18 20:06:16 UTC)
    Facets 1.0
foo_fileops (2024-05-01 16:33:00 UTC)
    File Operations 2.2 preview 2024-05-01
foo_freedb2 (2024-05-01 16:33:04 UTC)
    Online Tagger 0.10
foo_input_monkey (2023-03-22 21:34:46 UTC)
    Monkey's Audio Decoder 10.07
foo_input_std (2024-05-01 16:32:44 UTC)
    CD Audio Decoder 2.2 preview 2024-05-01
    FFmpeg Decoders 6.0
    FLAC Decoder 1.4.3
    Monkey's Audio Decoder 10.61
    Opus Decoder 1.5.2
    Standard Input Array 2.2 preview 2024-05-01
    WavPack Decoder 5.7.0
foo_musicbrainz (2023-02-23 11:53:04 UTC)
    MusicBrainz Tagger 0.5.0
foo_musicbrainz64 (2024-04-29 09:25:56 UTC)
    MusicBrainz64 2.5
foo_out_asio (2023-11-27 22:35:46 UTC)
    ASIO Output 2.2.2
foo_simplaylist (2011-08-18 20:01:36 UTC)
    SimPlaylist 1.0
foo_ui_std (2024-05-01 16:32:32 UTC)
    Album List 2.2 preview 2024-05-01
    Decoding Speed Test 2.2 preview 2024-05-01
    Default User Interface 2.2 preview 2024-05-01
    File Integrity Verifier 2.2 preview 2024-05-01
foo_unpack (2024-05-01 16:33:12 UTC)
    ZIP/GZIP/RAR/7-Zip Reader 2.2 preview 2024-05-01
foo_verifier (2023-04-17 02:43:48 UTC)
    File Integrity Verifier 1.4.3
foo_vis_milk2 (2024-02-19 09:51:42 UTC)
    MilkDrop 2 Visualisation 0.0.230-alpha
foo_wave_minibar_mod (2024-01-16 00:24:18 UTC)
    Waveform Minibar (mod) 1.2.58
Re: ASIO output seekbar wiggles backwards and forwards when paused.
Gah why did I title it as taskbar i meant seekbar.
Could a mod possibly change the title please.
Noted, thanks for reporting.
Fixed.
