Topic: CD rip has numerous timing problems (Read 1409 times) previous topic - next topic
hi folks,
I have a CD I've been trying to rip, but it was taking forever with EAC.  I also tried CueRipper and finally used Roxio Easy CD & DVD Burning to get what looks like a successful rip (sounds ok), but it took at least a couple of hours.
When I tried EAC, I used burst mode, as secure mode just wasn't going to do it.  I aborted after three tracks, but the log file indicated numerous timing problems - no suspicious positions which is what I'd expect if the disc were damaged.  The disc looks pretty good and plays without any audible issues on my CD player.
Any ideas what might be causing this or if there's any way to get a rip I can confirm as error free?
Exact Audio Copy V1.6 from 23. October 2020
EAC extraction logfile from 18. April 2024, 15:13
Bourne And MacLeod / Moonlight Dancers
Used drive  : ASUS    DRW-24B1ST   c   Adapter: 1  ID: 0
Read mode : Burst
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -5 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.32 |  4:03.08 |        32    |    18264
        2  |  4:03.40 |  3:37.00 |     18265    |    34539
        3  |  7:40.40 |  3:53.65 |     34540    |    52079
        4  | 11:34.30 |  4:51.57 |     52080    |    73961
        5  | 16:26.12 |  2:49.05 |     73962    |    86641
        6  | 19:15.17 |  3:40.10 |     86642    |   103151
        7  | 22:55.27 |  4:10.00 |    103152    |   121901
        8  | 27:05.27 |  4:01.58 |    121902    |   140034
        9  | 31:07.10 |  4:17.72 |    140035    |   159381
       10  | 35:25.07 |  4:35.28 |    159382    |   180034
       11  | 40:00.35 |  2:52.47 |    180035    |   192981
       12  | 42:53.07 |  3:58.70 |    192982    |   210901
       13  | 46:52.02 |  3:40.18 |    210902    |   227419
       14  | 50:32.20 |  4:43.67 |    227420    |   248711
Track  1
     Filename G:\Torrents\Bourne & MacLeod\1992 Moonlight Dancers (1992 CA Attic ACD 1343)\01 Oh Love.wav
     Pre-gap length  0:00:02.32
     Timing problem 0:00:12
     Timing problem 0:00:23
     Timing problem 0:00:27
     Timing problem 0:00:37 - 0:00:38
     Timing problem 0:00:40
     Timing problem 0:00:48
     Timing problem 0:00:54
     Timing problem 0:00:58
     Timing problem 0:01:00
     Timing problem 0:01:06
     Timing problem 0:01:11 - 0:01:12
     Timing problem 0:01:19
     Timing problem 0:01:21 - 0:01:22
     Timing problem 0:01:27
     Timing problem 0:01:36
     Timing problem 0:01:48
     Timing problem 0:01:50 - 0:01:51
     Timing problem 0:01:53
     Timing problem 0:01:56
     Timing problem 0:02:04
     Timing problem 0:02:10
     Timing problem 0:02:18 - 0:02:19
     Timing problem 0:02:22
     Timing problem 0:02:26
     Timing problem 0:02:28
     Timing problem 0:02:36
     Timing problem 0:02:40
     Timing problem 0:02:45
     Timing problem 0:02:49
     Timing problem 0:02:51 - 0:02:52
     Timing problem 0:02:56
     Timing problem 0:02:58 - 0:03:01
     Timing problem 0:03:03
     Timing problem 0:03:05 - 0:03:06
     Timing problem 0:03:08
     Timing problem 0:03:12
     Timing problem 0:03:14
     Timing problem 0:03:16 - 0:03:25
     Timing problem 0:03:27 - 0:03:31
     Timing problem 0:03:36 - 0:03:38
     Timing problem 0:03:41 - 0:03:43
     Timing problem 0:03:45
     Timing problem 0:03:47 - 0:03:48
     Timing problem 0:03:50 - 0:03:58
     Timing problem 0:04:01 - 0:04:02
     Peak level 90.7 %
     Extraction speed 1.9 X
     Copy CRC 03528CBC
     Cannot be verified as accurate (confidence 1)  [D3A9AB08], AccurateRip returned [1F9855EE]  (AR v2)
     Copy finished
Track  2
     Filename G:\Torrents\Bourne & MacLeod\1992 Moonlight Dancers (1992 CA Attic ACD 1343)\02 Home Sweet Home.wav
     Pre-gap length  0:00:00.73
     Timing problem 0:00:02
     Timing problem 0:00:04
     Timing problem 0:00:08 - 0:00:28
     Timing problem 0:00:30 - 0:00:36
     Timing problem 0:00:38 - 0:00:43
     Timing problem 0:00:46 - 0:00:52
     Timing problem 0:00:56 - 0:00:57
     Timing problem 0:00:59 - 0:01:01
     Timing problem 0:01:03 - 0:01:05
     Timing problem 0:01:07 - 0:01:12
     Timing problem 0:01:15 - 0:01:21
     Timing problem 0:01:24 - 0:01:26
     Timing problem 0:01:28 - 0:01:38
     Timing problem 0:01:40
     Timing problem 0:01:42 - 0:02:40
     Timing problem 0:02:42 - 0:02:45
     Timing problem 0:02:47 - 0:02:49
     Timing problem 0:02:51 - 0:02:59
     Timing problem 0:03:01 - 0:03:06
     Timing problem 0:03:08 - 0:03:24
     Timing problem 0:03:26
     Timing problem 0:03:28 - 0:03:31
     Timing problem 0:03:33 - 0:03:36
     Peak level 80.7 %
     Extraction speed 0.3 X
     Copy CRC 95A4E73B
     Cannot be verified as accurate (confidence 1)  [CE9132B7], AccurateRip returned [B4B3347E]  (AR v2)
     Copy finished
Track  3
     Filename G:\Torrents\Bourne & MacLeod\1992 Moonlight Dancers (1992 CA Attic ACD 1343)\03 The Circus Song.wav
     Pre-gap length  0:00:01.10
     Timing problem 0:00:00 - 0:00:24
     Timing problem 0:00:26 - 0:00:47
     Timing problem 0:00:49 - 0:03:53
     Peak level 53.9 %
     Extraction speed 0.1 X
     Copy CRC E4F6D5F4
     Cannot be verified as accurate (confidence 1)  [E8649EFD], AccurateRip returned [840C0BF0]  (AR v2)
     Copy finished
Track  4
     Filename G:\Torrents\Bourne & MacLeod\1992 Moonlight Dancers (1992 CA Attic ACD 1343)\04 Back To The Island-The Clumsy Lover.wav
     Copy aborted
Track  5
     Pre-gap length  0:00:01.12
     Copy aborted
Track  6
     Pre-gap length  0:00:01.34
     Copy aborted
Track  7
     Pre-gap length  0:00:01.55
     Copy aborted
Track  8
     Pre-gap length  0:00:01.67
     Copy aborted
Track  9
     Pre-gap length  0:00:01.60
     Copy aborted
Track 10
     Pre-gap length  0:00:01.36
     Copy aborted
Track 11
     Pre-gap length  0:00:00.45
     Copy aborted
Track 12
     Pre-gap length  0:00:01.27
     Copy aborted
Track 13
     Pre-gap length  0:00:00.57
     Copy aborted
Track 14
     Copy aborted
 3 track(s) could not be verified as accurate
11 track(s) canceled
No tracks could be verified as accurate
There were errors
End of status report
==== Log checksum 3F544F7CD58C03325352BA208F9D26AD765EA003404BC0F797BCAD4369E9B6A4 ====
MOD edit: Add log as code box
Re: CD rip has numerous timing problems
Burst mode doesn't have error detection/correction. A timing problem means a lot of time was needed to try to read the section. It doesn't always mean an error (but could).
korth
What else might cause the timing problems?  A poorly manufactred disc?
Also, when using burst mode with EAC or CUERipper, they both appear to be reading the sections several times - is that to be expected?
A few things that may cause timing problems:
Disc flaws,
label scratched or separating from polycarbonate,
scuffed, scratched or cloudy polycarbonate,
drive may have an issue with the reflective properties of a particular CD,
CD spinning too fast,
and probably more I can't think of.
Multiple attempts to read once can be expected.
CUERipper is able to do C2 error correction in Burst mode so up to 15 re-reads are possible if C2 error correction support detected.
korth
If this CD is presented in CTDB, you can use CUETools and try to verify and repair your rip, regardless of what program was used for ripping.
