Topic: Vorbis on (ultra) low end K6-2/350 CXT with Win95 (Read 1566 times) previous topic - next topic
Hi there,
what is the latest vorbis-version I can use on that machine. I currently have two encoders. Both are working they are:
oggenc.exe 259.584 bytes dated 08.03.2003
oggenc.exe 162.340 bytes dated 22.09.2004
I am using that machine above to encode via EAC/external Encoder on Win95b. The 2004 encoder is used in EAC, the other encoder comes with a vorbis 1.01 installation that also installs the winamp2x plugin. I currently use Q4 setting which is OK to me. The main target are small files with a good  audio quality. The current encoder seems to run at 1.x speed which seems to be quite good in terms of encoding-performance. So it's a question if I would get better quality with even small filesize with about the same encoding-speeds.
What would you suggest me to test/optimize ?
Thx
Doc
Re: Vorbis on (ultra) low end K6-2/350 CXT with Win95
thx, an "K6/3dnow-optimized" version does not exist so I will checkout the generic ones...perhaps it's better to go for newer versions in order to get the best quality out of the smallest size.
I have these available as older builds:
oggenc1.1.1.zip
oggenc2.1.zip
oggenc2.1_srcs.zip
oggenc2.2.zip
oggenc2.2srcs.zip
oggenc2.3.zip
oggenc2.3srcs.zip
oggenc2.5srcs.zip
oggenc2.5-SVNP3MOD.zip
oggenc2.6-1.1.1P3MOD.zip
oggenc2.6srcs.zip
oggenc2.7-aoTuVb4.51generic.zip
oggenc2.7-aoTuVb4.51P3.zip
oggenc2.7-aoTuVb4.51P4.zip
oggenc2.7srcs.zip
oggenc2.8-1.1.2P3.zip
oggenc2.8-aoTuVb4.51P3.zip
oggenc2.8srcs.zip
oggenc2.41-1.1.0P3.zip
oggenc2.41-1.1.0P3MOD.zip
oggenc2.41srcs.zip
oggenc2.42-aoTuVb3P3.zip
oggenc2.43-aoTuVb4P3.zip
oggenc2.81-1.1.2P3.zip
oggenc2.81srcs.zip
oggenc2.82-1.1.2generic.zip
oggenc2.82-1.1.2-MOD-generic.zip
oggenc2.82-1.1.2-MOD-P3.zip
oggenc2.82-1.1.2-MOD-P4.zip
oggenc2.82-1.1.2P3.zip
oggenc2.82-1.1.2P4.zip
oggenc2.82-aoTuVb4.51generic.zip
oggenc2.82-aoTuVb4.51P3.zip
oggenc2.82-aoTuVb4.51P4.zip
oggenc2.82srcs.zip
oggenc2.83-1.1.2generic.zip
oggenc2.83-1.1.2-MOD-generic.zip
oggenc2.83-1.1.2-MOD-P3.zip
oggenc2.83-1.1.2-MOD-P4.zip
oggenc2.83-1.1.2P3.zip
oggenc2.83-1.1.2P4.zip
oggenc2.83-1.2.0-generic.zip
oggenc2.83-1.2.0-P3.zip
oggenc2.83-1.2.0-P4.zip
oggenc2.83-aoTuVb4.51generic.zip
oggenc2.83-aoTuVb4.51P3.zip
oggenc2.83-aoTuVb4.51P4.zip
oggenc2.83-aoTuVb5.zip
oggenc2.83-aoTuVr1generic.zip
oggenc2.83-aoTuVr1P3.zip
oggenc2.83-aoTuVr1P4.zip
oggenc2.83srcs.zip
oggenc2.84-1.2.0-generic.zip
oggenc2.84-1.2.0-P3.zip
oggenc2.84-1.2.0-P4.zip
oggenc2.84-aoTuVb5-generic.zip
oggenc2.84-aoTuVb5-P3.zip
oggenc2.84-aoTuVb5-P4.zip
oggenc2.84srcs.zip
oggenc2.85-aoTuVb5.5-generic.zip
oggenc2.85-aoTuVb5.5-P3.zip
oggenc2.85-aoTuVb5.5-P4.zip
oggenc2.85-aoTuVb5.6-generic.zip
oggenc2.85-aoTuVb5.6-P3.zip
oggenc2.85-aoTuVb5.6-P4.zip
oggenc2.85-aoTuVb5.61-generic.zip
oggenc2.85-aoTuVb5.61-P3.zip
oggenc2.85-aoTuVb5.61-P4.zip
The oldest is from 2003 and the newest from 2008. I can make any available as you wish.
that would be nice. thx!
I suspect that P3 and P4 versions won't work on AMD K6-2.
right, the k6 has mmx/3dnow that was it, no sse1/2 etc.
I'll post generic versions to Rarewares and post here with links when they're available. It will probably be tomorrow now. :)
no problem, thx!
thx!!
