Topic: Selection text color and background in Library tree is not applied from prefs (Read 747 times) previous topic - next topic
I use old school WinApm color style. After update foobar2000 from v. 1.x to the latest 2.1.1, the selected item in the library tree is almost invisible because it uses the default colors, not the colors that are set in Preferences. The screenshot is attached.
Re: Selection text color and background in Library tree is not applied from prefs
Fixed in v. 2.1.2, thank you!
Another and much older issue with the background color of the Library tree:
Sometimes after unlocking Windows from the sleep mode the background turns to the gray. The screenshot is attached. The issue is not regular (or maybe depends on the sleep mode and does not appear when just locking the screen). Any repaint like minimize/maximize window or moving the split bar returns the black background. Foobar2000 version 2.1.2, Windows 11.
