Topic: foobar 2.0 crashes when trying to access ASIO drivers (Read 1836 times) previous topic - next topic
On Windows 11 latest build, using Foobar 2.0 64bit.
I have the following components:
1. ASIO+DSD Output v0.3.6
2. Super Audio CD decoder v1.4.7
Under  Output>ASIO+DSD I double click the foo_dsd_asio driver and then foobar crashes.
Is there any other info I need to provide?
Re: foobar 2.0 crashes when trying to access ASIO drivers
Super Audio CD Decoder (foo_input_sacd)
Support foobar2000 v2.0 from v1.5.0 x86 x64 (2022-09-01)
Latest version v1.5.5
https://sourceforge.net/projects/sacddecoder/files/foo_input_sacd/
-Preferrences > Tools > SACD > DSD > Output (per device) > Type > DSD or DSD+PCM
-Output: ASIO+DSD: DSD DAC ASIO Driver
Playlist View > DSD file Double click
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Thank you.
I got it working now.
By the way, use Zen DAC v2 with the latest drivers and firmware from iFi.
I followed a PDF guide on how to setup Foobar for DSD playback.
When I try to play a DSD512 file, I get: "Unrecoverable playback error: Sample rate of 22579200 Hz not supported by this device"
But as far as I know, The Zen DAC v2 should support DSD512.
In Windows11 I have the Zen DAC set to 24bit 384KHz.
Do you know if it's possible to playback a DSD512 via foobar if my DAC supports DSD512?
Lastly, is it possible to apply some EQ on a DSD playback via foobar?
Please assume that the latest settings for all manufacturers are incorrect.
(foo_input_sacd + foo_out_asio+dsd)
The settings are only on the screen above.
↓ Please check again. Have you returned to PCM?
Are the colors around the volume changing?
Native playback: basically should not be used.
Check if it can be played properly.
Are you kidding me?
Foobar2000 - Error: "Unrecoverable playback error..."
https://www.head-fi.org/threads/foobar2000-error-unrecoverable-playback-error.965497/
> DSD512 file
Maybe it's a *.dff file?
iFi Driver seems to be weak
I can't play it with my ZEN DAC and iFi CAN nano.
Please convert to .dsf with foo_dsd_converter.
foo_dsd_converter
https://sourceforge.net/projects/sacddecoder/files/foo_dsd_converter/
This is how i have it set up: https://imgur.com/a/i0cAp8i
MOD edit: move reply out of quoted text
The settings are above, and there is nothing special on the foobar2000 side or the DAC side.
Try.
foo_dsd_converter or Convert DSD to WavPack DSD
Compressing DSD files with Wavpack 5
https://diyaudioheaven.wordpress.com/digital/pc-software/compressing-dsd-files-with-wavpack-5/
WavPack DSD playback settings are the same as DSD playback.
DSD Processor (foo_dsd_processor)
Not used for DSD playback or DSD Native playback.
Use with Audio Devices that do not support DSD.
It is distributed as a DSP component (different functionality).
foo_dsd_processor-1.3.0-2.zip   2023-07-13
https://sourceforge.net/projects/sacddecoder/files/interim/
