Topic: When converting any file to DSD64/128/256 the converted file last 1 second (Read 3665 times) previous topic - next topic
As in topic, when converting any file to DSD64/128/256 the converted file last 1 second, i have all the components needed to play DSD up to 256 by native.
Re: When converting any file to DSD64/128/256 the converted file last 1 second
How are you doing the conversion (the software and settings you're using in foobar2000) and what version of foobar2000 are you using?
how to check the version?
In the main menu, help, about.
its v1.6.16
and for the first part of my question?
i have all being set up as on the picture i attach here and i have all components needed to play dsd natively, i know this because volume bar isn't working
To play you need
foo_input_sacd + foo_out_asio+dsd
what you need to convert
DSD Converte (foo_dsd_converter) + DSD Processor
Playlist View Context menu > "Convert -> DSD convert"
Super Audio CD Decoder Files
https://sourceforge.net/projects/sacddecoder/files/
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
i have all this you mentioned, maybe i mess up some settings in the DSD Processor tab, can you give me yours?
What's going on with file size?
foobar2000 Preferences > Tools > SACD > Converter > DSD Processor
"DSD Processor" You do not need to do anything in particular because it is a setting that is done as needed.
Try:
Context menu > Convert > DSD convert > Output format > DSF
foobar2000 Preferences > Tools > SACD > DSD+PCM
Output:
foobar2000 Preferences > Playback > Output > Device > ASIO+DSD: DSD DAC ASIO Driver
Don't use DSP Manager and Output Fading.
i had most of the settings as you posted, i cleaned also dsp manager and still convrted dsd file last below 1 second
If I were to debug issues like this, I would have tried to set up a completely new portable fb2k, and see what possibly makes it work.
That was surely not specific enough for this particular issue. Converting to DSD is something I would only do out of curiosity, after all it is not a useful format.
What is the model name of the DSD DAC?
Can normal DSD files be playback DSD Native ?
Show me the Screen Shot in the setting window.
-DSD file (converted) - Properties Details tab
-foobar Preferences > Tools > SACD > Output (per device)
-foobar Preferences > Playback > Output > Device
-Playlist Context menu > Convert > DSD convert > DSD Converter Setup
i would explain you scientifically why it is a lot better than any pcm but it would be an offtop, besides i believe my ears
will post it here, just give me few minutes...
edit: its Creative Sound Blaster Audigy FX V2 with DBPro module daughter card that supports DSD playback up to DSD256
here are the images
]i would explain you scientifically why it is a lot better than any pcm but it would be an offtop,
Some forum members are trained scientists who would be happy to know. Or unhappy to get just another round of that mumbo-jumbo.
When you signed up for this service, you agreed to the terms of service: https://hydrogenaud.io/index.php/topic,3974.html
I refer you to item #8. Post the evidence in this thread, or under listening tests with link in this thread.
Do not use DSD Processor now.
2ch, right?
foobar side setting is not wrong.
i do not want to argue
2ch, right?
Thanks, it helped! just selected "None" in the DSD Processor in Tools > SACD
edit: problem still persists, seems like i wanted to convert the .dsf file to .dsf...
edit2: problem persists but only with .mus files...
edit3: when the converting of mp3 file comes to an end, the error occurs "Invalid Parameters"
Is SID Player installed?
SID Player
https://www.foobar2000.org/components/view/foo_sid+%28x64%29
Commandline Encoder Setting
Extension: mp3
VBR
Parameters: -S --noreplaygain -V 0 - %d
CBR
Parameters: -S --noreplaygain -b 320 - %d
Highest BPS mode supported: 24
Are the file types different?
i do not understand the second part of that post and the sid player wasnt installed, beside that it plays .mus files fine
edit: even with SID player the converted file last below 1s
You committed to it when you signed up.
OK but this topic isnt about if difference between DSD and PCM exist, create other thread for that, and chill. it will become an offtop if we will argue about, and i need just help, for sure you may find proper forum where they will explain to you why dsd is exactly better and on what exactly it relies on, and why it outperform any PCM format, just not here, ok? And that DSD is better it isnt that like i just invented this argument, i rely on what has been scientifically proved, not just believe my ears.
i still wait for response
