Topic: [fb2k v2] Playlist tour (Read 8042 times) previous topic - next topic
Hi there,
Playlist History (now Playlist Tour) by Sami Salonen gets ported to foobar2000 v2 (32/64bits)
Now also including a new UI element to assist in browsing recently activated/played playlists.
Minimum requirement fb2k v2
Thanks for testing!
X
Playlist Tour v0.1.7
X(
Screenshoot
Re: [fb2k v2] Playlist tour
Nice catch!
64 bit dll:  Report is priscine clean.
32bit dll:  Virus total reports it´s been Wacatacked (meaning file is not signed).
Could not find any reference to the abort part, but this issue seam to have been fixed nevertheless.
Bellow are the links to latest (clean) results:
v0.1.7 64bits signed
891b80abc971fcc0119c1bb99eaf304b1acbc6ab5ca23f8bf69fe2919e0db98e
https://www.virustotal.com/gui/file/891b80abc971fcc0119c1bb99eaf304b1acbc6ab5ca23f8bf69fe2919e0db98e?nocache=1
v.0.1.7 32bits signed
817a1e6c0fb073c737aae1a552314ba8871f458a2e99e39e66fc03d508810f5e
https://www.virustotal.com/gui/file/817a1e6c0fb073c737aae1a552314ba8871f458a2e99e39e66fc03d508810f5e?nocache=1
And Playlist Tour signed and repacked... happy and healthy as a clam!
X
Playlist Tour v0.1.7 (signed)
Minimum requiments: foobar 2000 v2
BSD License
Edit: fix duplicated reports
Still surprised no one reported any crashes...
Although we had the Wacattack moment anyway!  :))
I agree; it's a shame that the feature was left behind at the last moment, and also, the Max history size value (50 items) could be customizable. It appears to be a barebone component and maybe we should keep that way. Will try to include those two features in next release anyway.
Request: Please populate panel with active playlist on foobar2000 startup. The panel is currently empty.
It now restores the last recent playlists on startup.
There is a new context menu (option to clear recent playlists and to reorder recent playlists in the playlist tabs).
Also fixed some crash scenarios and set a new text style for the playing list.
X
Playlist Tour v0.1.8
BSD License
X
Screenshot
Thanks. There is on the bottom of the panel a horizontal scrollbar. Please avoid this.
EDIT: Could modify size by adjusting the header. But after resize of the panel, that setting is lost.
You´re welcome and thank you for pointing that out.
It should be fixed in this release.
The column width is now set to autosize on the first run, then saved as a fixed value.
And also...
- Added the setting for Max history size (from 5 to 50 rows) in the preference panel.
- Fix: Reorder and inverse reorder playlists not matching the history list.
- Fix: History list update on playlist rename.
Thanks again for pointing out the bugs!
X
Playlist Tour v0.1.9
BSD License
Hello
Here is the forth and maybe one of the last releases,
Thanks for testing!
Changelog:
- Revised tab reordering.
- List control update (keyboard improvements and multiline selection).
- Polished context menu (default action, remove, and reset played status).
X
Playlist Tour v0.1.10
BSD License
X
Screenshoot
Not sure if we talk about the same sceneario.
The seudo code for removing the played mark starts with 'Is this the playing list ? exit'
Another current bug or feature aspect is if playlist activation from the UI history list should act exactly in the same way than the menu options.
 :)  The second part of the message has no relation with it, just wrote it in case some other people may find inconsistencies in the way history navigation works in the latest release.
@grimes
"Mark as unplayed" is working here with items other than the current playing playlist.
I took note of the scrollbar issue.
About the CUI panel, it is not going to happen soon.
It requires more work than I initially thought...  :-\
New release available:
Change log:
- 2023-05-10 Foobar 2000 SDK
- SDK version/target added to 'About component'
Playlist Tour v0.1.11
X
Hi :)
Can "Playlist Tour" change the background color?
Playlist Tour v0.1.11 (2023-05-13)
foobar2000 v2.0 32bit Default UI element
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Hi :)
Hi there!
I forgot about custom colors in the last releases  :'(
What's new:
- Customize colors and fonts.
Fixes:
- List control using playlist instead default font.
- Multiple UI instances list control updates in some scenarios (partial fix).
- Crash deleting multiple selections.
Known issues:
- Playlist not marked as played in some scenarios.
- Multiple ui component not fully supported (refresh/sync issues).
- Pending grayed (active playlist) and hotlight (playing playlist) font color revision.
Thanks for testing!
Playlist Tour v0.1.12
X
@da yuyu
Many Thanks.  :D
Here is the latest release.
It just patches the last fix related to deleting multiple selections.
Playlist Tour v0.1.13
 foo_playlisttour.zip  (369.71 KB)
MOD edit: changed attachment to non-image.
Hi there!
Component now features a Columns UI panel...
Playlist Tour v0.1.14
 Playlist Tour v0.1.14.zip  (372.85 KB)
