Topic: Split 32bit wavepack file using .cue file (Read 2006 times) previous topic - next topic
Hello guys, I have 32bit 192KHz vinyl rip in wavepack format. I have the .cue file. Which software can split it without losing quality or something??
Re: Split 32bit wavepack file using .cue file
Not my rip
MOD edit
I've never used WavePack but I just did some quick experiments and Audacity can open & edit WavePack if you install the optional FFmpeg Import/Export library.
It doesn't seem possible to export as 32-bit WavPack from Audacity (I got 16-bits and I don't see a way to change it) but you can export as 32-bit WAV (floating-point or integer) and then convert to WavPack with TAudioConverter (if you want to keep WavePack).
refalac can, if you put the wavpackdll.dll in the same folder. Use -D to get .wav rather than .m4a
It can also decode FLAC files and - if you use the 32-bit version - TAK.
