Topic: Speex Commandline Options (Read 3701 times) previous topic - next topic
I have a problem using the commandline using this compilation.
The commandlines I have tried are:
speexenc -wideband -abr 24576 -nframes 8 -comp 10 -V "filename" "outputname"
ERRORMESSAGE: invalid option -- i
speexenc -wideband -bitrate 24576 -nframes 8 -comp 10 -V "filename" "outputname"
speexenc -wideband quality 8 -vbr -nframes 8 -comp 10 -V "filename" "outputname"
speexenc -wideband -bitrate 24576 -comp 10 "filename" "outputname"
speexenc -bitrate 24576 -comp 10 "filename" "outputname"
ERRORMESSAGE: invalid option -- b
This however worked:
speexenc "filename" "outputname"
Any suggestions as to how to fix this? It's vital for encoding CDs.
EDIT: I think I found a solution...
> "outputname"
speexenc -w --abr 24576 --nframes 1 --comp 10 -V in.wav out.spx
Have you ever tried "spexxenc --help" ?
Apparently, I forgot using --, I used -.
Thanks, though
