Topic: Weird issue with AAC ripped files. Foobar makes them appear out of order. (Read 965 times) previous topic - next topic
I'm having a weird issue with foobar. The program rips files in AAC (apple) with ease, but the files themselves aren't named with 1, 2 ,3..etc
The result of that is that they appear out of order, which is a bit bizarre. I either have to choose "list by #" or have to individually name each track starting with a number. It's not a huge issue, but it makes me feel like I'm back in 2003, individually ripping cd titles one by one with Creative player.
Can I suggest the next version of foobar fixes this issue?
Re: Weird issue with AAC ripped files. Foobar makes them appear out of order.
In section "Destination" of Converter's settings in "Name format" line use [%tracknumber%. ]%title% instead of %title%
Also, you can easy rename files right from within of fb2k. Select files in playlist, right click->File opertaions->Rename to->...
Enter [%tracknumber%. ]%title% in "File name pattern", then press Run.
Wow that was a surprisingly quick fix to my issue. Thank you for the speedy response, it totally fixed my problem!
