Topic: FTP Transfer Of Audio Files To Phone (Read 6720 times) previous topic - next topic
FTP with Foobar2000 app works well for me, however . . .
I was copying my audio files (about 70GB) from my computer to my phone via Foobar2000 FTP server, got to 85%.
I then accidentally interrupted the copying.
Now I don't know how to copy *only* the remaining files, and I don't know if the last file to copy was partially copied, or removed so that the 2nd to last file is complete. I don't want a partial song.
I tried comparing source and destination folders in WinMerge but I couldn't open the FTP in that program.
When trying to copy ALL files again (and hoping to "ignore" the already existing files in destination), of course, Windows 10 just gives up trying to find all the files that already exist in destination, and does nothing.
To get to 85% took many hours. So I don't really want to delete all off phone then copy all again.
Help?
Re: FTP Transfer Of Audio Files To Phone
Would it be an option to connect the phone via USB to do the copying and would be faster?
The reason I'm using FTP is because when I copy via USB the phone randomly disconnects from the computer not far through - USB copying is unbearable.
In Windows 10 power options "USB Selective Suspend" is indeed OFF.
And there's no lint in my phone's USB port.
I never used FTP on my phone so I cannot help you there. I have couple of ideas you can try.
1. If your phone has SD card, eject the card, plug it in your PC, copy files, put SD card back in the phone.
2. If you think there is a problem with Windows 10, you can boot live Linux distro and try to copy files from there.
3. If you have USB OTG adapter, you can use flash drive to copy your files.
70 GB of music is a lot. I assume you are using FLAC. For me, average FLAC bitrate is around 950 kbit/s.
By converting your music to AAC-LC at 192 kbit/s you will reduce size by ~55 GB.
gold plated toslink fan
When I used to use Arch Linux as my main OS I would have no issue copying.
I will try your ideas 2 and 3. I don't really want to buy an SD Card reader unless I have to.
Have you tried going to device manager and going to the power management tab for the usb devices and disable the allow this device to power off (or something along those lines).
You could also try installing Linux in Windows. I installed Ubuntu LTS which is on on the windows store. https://www.microsoft.com/en-us/p/ubuntu/9nblggh4msv6?activetab=pivot:overviewtab
As in Reply #2, yes that setting is already disabled.
I will try Linux within Windows, it seems to be a Windows problem - I suspect with an SD card reader it would have the same issue - and if I copied the files from a flash drive through adapter to phone the phone might run out of battery and it could take ages.
That's a different setting and might not help.
The device manager route may fix your issue. It has help me recently when my soundcard was cutting out.
Under universal serial bus controllers and props of each usb uncheck this.
Oh sorry I misread. I've never seen this setting. I will try that and get back to you in a bit.
The setting was already turned off on all USB devices/hubs in Device Manager. I just tried a motherboard USB on the back of my desktop instead of the front "chassis USB's" but it didn't help either.
Strange, I thought the default was them checked.
I'm all out of ideas apart from not letting the phone go to sleep by setting the display to always stay on in the dev settings while it's charging which I assume it is when it's plugged in via USB.
That display always on idea might actually be worth checking out.
For now though I've given in and I'm just transferring everything again via FTP.
I believe when I had Arch Linux it did not have this issue either. Arch didn't give up trying to find the files already in destination.
That's 2 points for Linux (USB stays connected, and copying large number of files is not buggy), and 0 for W10.
I will test if having display on keeps USB connection happy after the FTP is finished, and I will get back with the result.
in case someone finds this later on, I have had successful transfers with 'FTP Manager Lite' and long duration transfers. It seems to keep the connection open, when other apps didn't, and it asks to over-write if the content is already there. that's my two cents. cheers CD
USB is usually the easiest (on Linux anyway), maybe you can find another cable, it can happen if a cable is damaged or defective.
About FTP, on the same Google Play account as foobar2000, is https://play.google.com/store/apps/details?id=com.foobar2000.ppftpd maybe something to try.
a fan of AutoEq + Meier Crossfeed
I'm using WinSCP to sync my music with my phone over FTP. Once you open the ftp connection in WinSCP go to the commands menu and there is a synchronize option that will compare the local folder (left pane) to the FTP server (right pane) and only copy over the difference.
