Topic: CUETool how do you extract to multi tracks ? (Read 3146 times) previous topic - next topic
Hello Guys
thank you in advance for any help
Ok I'm using EAC to rip my CDs to one wav file + cue sheet
I now need to extract multiple wav files from the single  (Whole Album) Wav file without damaging any audio files
I was using an easy to use program called medieval cue sheet splitter that worked well, but been informed it damages audio etc so staying away from that program
Can someone please explain how to do the same thing in CueTool, I have tried everything but can't see how to extract wavs tracks ?
what am I missing to extract to multiple Wav Files
Thank You
No Half Measures With Audio, Perfection is the only way every time
Re: CUETool how do you extract to multi tracks ?
Hi
I'm not sure if it me, but what should be the easiest thing to do in CueTools (split the Big Wav, Into lots of little Wavs, Tracks) seems to be the hardest thing to do.
Where is the big button SPLIT ?
How hard can it be to put a big button that says "Split Big Wav To Tracks" ?
I have looked everywhere, I can create another cue file, but not split wav ?
The control and layout leaves a lot to be desired
This is not easy software to use, albeit it's free,
I have even search the help and find that limited on how to achieve this goal, so i'm fast running out of ideas and thinking this will not split the wav file
I have even tried searching through the help in the forum and still can't find the answer ?
what option do you choose Encode? Verify? Create Cue Sheet? Correct File Name?  none of these seem right.
any help will as always will be appreciated
regards
MOD Edit: Get rid of multiple question marks and blank lines
"None" in Audio Output is telling CUETools you don't want audio files. Select "Lossless" instead.
http://cue.tools/wiki/CUETools_Settings
korth
Thank you for your reply, yes found it in the end, needed to take it of None....
Though
Audio quality of extract wav in CueTool not great ?
The extracted audio Wav that CueTool has extracted from the Big Wav file is not as good sounding
Not impressed with the encoded small track wavs, they sound flatter and lost some of the sparkle that the EAC big wav has
are there any settings to adjust ?
under WAV I can see no settings to adjust
I also noticed when Ripping using CueTool Ripper, the same CD Rip sounded better by EAC,
The cue tools Ripper version lost its Sparkle and Stereo depth, sounded flatter and not as wide !!!
It looks as if something is going on with the CueTools encoding of wav files !!
I am using a very high end studio RME Sound Card, I can hear everything when it come to the quality of music on this baby, RME is seriously one of the best makes of studio Sound hardware
and there is deffo some thing not as pleasing to my ears with the CueTools Rip vs the EAC Rip
It looks like I may have to use EAC and just rip to separate tracks to get the best quality, I don't think splitting big files is going to work ?
I have now just done a test with medieveal Cue sheet extractor, it does a better job that CueTools in quality, but still not as good as the original EAC big Wav
But deffo better sounding wav than CueTools extracted wav file ?
Ok I think I have my answer,
Only Rip from EAC and only play those Wav, don't let any program re encode Wavs, if I want to keep the original quality of the Plextor Premium II RIP & EAC
Thanks for any help
Go to Settings > AccurateRip
http://cue.tools/wiki/CUETools_Advanced_Settings:_AccurateRip
Under "Verify", check "Write AccurateRip log" and "In source folder"
Run "Verify" (instead of "Encode") on the original CUE + Big Wav (EAC rip).
Run "Verify" on the new individual wav files you created when you split the Big Wav.
Post the contents of the accurip file created in source folder AND the contents of the accurip file that was created in the folder with the new individual wav files. The accurip file can be opened in a text editor like NotePad.
korth
EAC RIP
CUETools log; Date: 19/06/2021 18:38:01; Version: 2.1.9]
[CTDB TOCID: _5uZHhk5aDg9ptx3O9EqwPGf8zg-] found.
Track | CTDB Status
  1   | (33/33) Accurately ripped
  2   | (33/33) Accurately ripped
  3   | (33/33) Accurately ripped
  4   | (32/33) Accurately ripped
  5   | (33/33) Accurately ripped
  6   | (33/33) Accurately ripped
  7   | (32/33) Accurately ripped
  8   | (33/33) Accurately ripped
  9   | (33/33) Accurately ripped
 10   | (32/33) Accurately ripped
[AccurateRip ID: 001d39e9-00e8f564-8c12720a] found.
Track   [  CRC   |   V2   ] Status
 01     [7c974ec8|2663918f] (00+11/11) Accurately ripped
 02     [f8c8c9e1|66a03cdf] (00+12/12) Accurately ripped
 03     [405ebf98|f98dac6c] (00+12/12) Accurately ripped
 04     [be5fc971|b2f453d2] (00+12/12) Accurately ripped
 05     [388f1b36|40e68bf2] (00+12/12) Accurately ripped
 06     [f84f8cd6|061c2bb5] (00+12/12) Accurately ripped
 07     [523aca90|080af316] (00+12/12) Accurately ripped
 08     [54a6fce8|b524bb23] (00+12/12) Accurately ripped
 09     [2f1625b0|bd74f6c1] (00+12/12) Accurately ripped
 10     [3419d259|1d0b46b0] (00+11/11) Accurately ripped
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --   98.3 [E053023A] [BBDC9036]   CRC32
 01   97.9 [7F122BFA] [E0EAA337]
 02   98.3 [E21B903C] [F9EAA9EA]
 03   97.9 [0D9F6817] [968A7FE3]
 04   97.9 [9D303FF6] [7DA445AE]
 05   97.9 [80FC5755] [5538FF3D]
 06   97.7 [FE8FACF0] [D3581C03]
 07   97.9 [A5322EF2] [2615B768]
 08   97.9 [33FDF296] [B560BB25]
 09   98.3 [EF997964] [BB27F81C]
 10   97.7 [BB7FDD61] [DBEA68E6]
CUE TOOLS TRACKS RIP
This is NOT as pleasing on the ears, dull and not as vibrant / wide as the EAC rip
[CUETools log; Date: 19/06/2021 17:57:54; Version: 2.1.9]
Track | CTDB Status
I notice both log files have the same checksums they deffo sound different
Logs show no difference in audio hashes but time stamps are 40 minutes apart. Please run "Verify" on both, just to be sure.
korth
Hi
thanks for your reply
I just noticed my sound card setting was in 192000hz (Hi Res Audio)
I have reset back to (44100hz) (CD Quality, now there seems be no difference, audio sounds good from original and track rip
still doing more testing but checksums coming out the same in both
Am I right in thinking
So once CUEtools splits the audio files from the big EAC wav, it then checks  the CRC against the Accurip database of the new small Track Wav ?
Thanks for your help and input
CUETools calculates the CRCs as the audio is processed (not after the new files are created).
korth
thank you for the info
so your saying it's a very bomb proof method of extracting audio from the large wav
regards
Both EAC CueTools allow to rip the CD to tracks, you don't need to first rip into image+cue than rip that image+cue again with CueTools to tracks.
