Topic: Masstagger: syntax to reduce date field (Read 2384 times) previous topic - next topic
Hi there.
Could someone please let me know what syntax I could use in Masstagger to reduce date field to four-digit year?
I know Tag Sanitizer does that, but this component has deleted more tags in my files than I specify, so I've gotten along better with Masstagger itself.
Thanks in advance.
Re: Masstagger: syntax to reduce date field
There you go
$cut(%date%,4)
@Fabcore
Thank you very much!
Thanks! :)
Hi
is there a way to capitalize letters of several fileds like artist album and songs ?
for example change nick cave to Nick Cave ,songs like No Nore Shall We Apart and the other songs
I have read the guide but i have not found an answer , it's so powerfull plugins , could be added the feature capitalize
thanks
Don't think that is related to the thread topic? I'm assuming it isn't:
File properties, highlight the fields in question (you can highlight several), right-click, "Capitalize".
It will make all the stupid mistakes (like capitalizing A and The and Roman Numeral Iii), but you cannot have it all without more work ... which you can often let https://www.foobar2000.org/components/view/foo_musicbrainz do for you.
Hi Porcus
but  foo_musicbranz is to tag an album online
i just wanted to capitalize some fileds.. maybe to do it are better ofther freeware like mp3tag because i can't find anything to do with masstaggger
thanks
Here is a MassTagger preset function that decapitalizes a list of common 3-letter and shorter words and makes some exceptions. Minimal manual fixup is required. It is not possible to perfectly automate the process because phrasal verbs need to be understood in context. It processes artist, title and album, but you can add more fields at the start and end. Use the "Import from file" button to load the preset.
