v0.5.0-beta.8?
Segoe UI is the default font for the tooltip AND the fallback font when others fail. I don't really get why it crashes (?) if the font is installed on Wine (no matter if it's the default one or not). Also if doesn't crash on windows if the font is missing. Did you change the default font or installed Segoe UI? Maybe it was not installed and was added when setting it as default? Could you revert back the default one and check? Can you provide the crash message?
The last part may be related to a wine thing, but you are the first reporting problems with it on wine (?) and nothing has changed related to that on months. I will definitely try to find what's going on but it will take some time.
I will probably need some help with that. Would you mind doing some testing with alt. files?
(could you check if my other scripts work for u? World map, playlist tools)
the version is Playlist Manager v0.5.0-beta8 by XXX). From git clone.
The font was installed before. Other scripts like last.fm charts or bio print in console
Last.fm Similar Artists + User Charts + Recent Tracks: Unable to use default font. Using Segoe UI instead.
when the default font is not Segoe UI.
But Playlist Manager crashes with
Error: Spider Monkey Panel v1.6.2-dev+7c0928bf ({89CB6BF3-C1B2-4C9A-8872-E14774FED3A1}: Playlist Manager v0.5.0-beta8 by XXX)
N is not defined
File: playlist_manager_panel.js
Line: 48, Column: 4
Stack trace:
_panel/this.fontChanged@playlist_manager_panel.js:48:4
_panel@playlist_manager_panel.js:112:7
@playlist_manager.js:155:13
World map work without problem, but playlist tools crash the program completely when I tried to add it.
Illegal operation:
Code: E06D7363h, flags: 00000001h, address: 7B0122E6h
Additional parameters: 19930520h 0021C228h 06B5714Ch
Message: argument not found
Last win32 error: 3
Call path:
entry=>app_mainloop
Code bytes (7B0122E6h):
7B0122A6h: 83 EC 6C 8B 59 04 8B 31 C7 45 A0 00 00 00 00 8B
7B0122B6h: 41 08 8B 51 0C C7 45 A4 90 22 01 7B 83 E3 01 89
7B0122C6h: 75 98 89 5D 9C 85 C0 74 04 85 D2 75 2D C7 45 A8
7B0122D6h: 00 00 00 00 8D 45 98 89 04 24 FF 15 40 9B 0D 7B
7B0122E6h: 83 EC 04 8D 65 F4 59 5B 5E 5D 8D 61 FC C2 10 00
7B0122F6h: 8D B4 26 00 00 00 00 8D 76 00 83 F8 0F B9 0F 00
7B012306h: 00 00 0F 47 C1 89 45 A8 C1 E0 02 8B 4C 02 FC 89
7B012316h: 4C 05 A8 83 E8 01 83 F8 04 72 B9 83 E0 FC 31 C9
Stack (0021C164h):
0021C144h: 665C6E69 61626F6F 30303272 72705C30
0021C154h: 6C69666F 0021C1D8 7B0122E6 0021C170
0021C164h: 00000000 0021C190 00000013 E06D7363
0021C174h: 00000001 00000000 7B0122E6 00000003
0021C184h: 19930520 0021C228 06B5714C 026A0000
0021C194h: 00000000 00000013 70B73406 026A0000
0021C1A4h: 00000000 0021C1CC 70B74177 0073006A
0021C1B4h: 23BA0000 0021C1DC 70B74177 0021C210
0021C1C4h: 00000013 00000013 0021C1F0 19930520
0021C1D4h: 06B23A81 0021C218 06AC67AD 0021C1F0
0021C1E4h: 06AC7ED7 0021C218 06AC67AD E06D7363
0021C1F4h: 00000001 00000003 0021C20C 0021C518
0021C204h: 0021C2CC 0021C228 19930520 0021C228
0021C214h: 06B5714C 0021C258 0694E984 0021C228
0021C224h: 06B5714C 06B12BA8 4679C800 00000001
0021C234h: 06B05114 00000000 00000000 06B11BC0
0021C244h: 0694EA01 0121C2C8 0021C57C 06AEB17D
0021C254h: FFFFFFFF 0021C2C0 0694EA0D 06B23A80
0021C264h: 06B23A83 0021C310 0021C2C0 0000000F
0021C274h: 00000000 0021C5B8 0000003A 0021C310
Registers:
EAX: 0021C170, EBX: 0021C228, ECX: 00000008, EDX: 0021C20C
ESI: E06D7363, EDI: 06B5714C, EBP: 0021C1D8, ESP: 0021C164
Crash location:
Module: kernelbase
Offset: 122E6h
Symbol: "RaiseException" (+51h)
Loaded modules:
explorerframe loaded at 676C0000h - 6771F000h
cryptnet loaded at 0F230000h - 0F273000h
psapi loaded at 67840000h - 6784F000h
rsaenh loaded at 6FE40000h - 6FED7000h
schannel loaded at 6DD00000h - 6DD1C000h
msxml loaded at 71040000h - 7105C000h
msxml3 loaded at 41340000h - 41D25000h
msctf loaded at 6F900000h - 6F9F3000h
wintrust loaded at 6F4C0000h - 6F560000h
setupapi loaded at 6BCC0000h - 6BE61000h
userenv loaded at 0EFC0000h - 0EFE3000h
lgpllibs loaded at 0F9C0000h - 0FAD3000h
mozglue loaded at 0F8C0000h - 0F9BD000h
nss3 loaded at 0F6B0000h - 0F8BF000h
xul loaded at 2D5A0000h - 32BF4000h
mshtml loaded at 24020000h - 25596000h
scrrun loaded at 0EF90000h - 0EFB6000h
wshom loaded at 0EF70000h - 0EF8C000h
atlthunk loaded at 66540000h - 66554000h
foo_dsp_sqrcomp loaded at 0BCE0000h - 0BCEE000h
foo_dsp_vocal_exciter loaded at 0BCC0000h - 0BCD4000h
foo_enhanced_playcount loaded at 0BC80000h - 0BCB5000h
foo_ui_std loaded at 0AB70000h - 0AC79000h
foo_runcmd loaded at 0A930000h - 0A963000h
foo_uie_albumlist loaded at 0A8B0000h - 0A923000h
avutil-fb2k-56 loaded at 0A600000h - 0A8A6000h
avcodec-fb2k-58 loaded at 0A440000h - 0A5FB000h
foo_input_std loaded at 0A2E0000h - 0A439000h
foo_rgscan loaded at 0A290000h - 0A2DA000h
foo_dsp_replaygain loaded at 0A270000h - 0A283000h
foo_simplaylist loaded at 09F20000h - 0A06C000h
foo_texttools loaded at 09CE0000h - 09D14000h
foo_textdisplay loaded at 09A90000h - 09ADB000h
foo_dsp_std loaded at 09A50000h - 09A86000h
foo_stop_after_queue loaded at 09A40000h - 09A4D000h
foo_freedb2 loaded at 09A10000h - 09A40000h
foo_unpack loaded at 099A0000h - 09A0E000h
foo_musical_spectrum loaded at 09780000h - 0979C000h
foo_uie_typefind loaded at 09750000h - 09773000h
foo_dsp_eq loaded at 09710000h - 0974D000h
foo_simplaylist_manager loaded at 09430000h - 09508000h
foo_quicksearch loaded at 091D0000h - 09227000h
foo_vis_vumeter loaded at 08D20000h - 08DC5000h
foo_uie_console loaded at 08CE0000h - 08D17000h
foo_facets loaded at 08920000h - 08AD5000h
foo_lrc_metalarchives loaded at 08880000h - 08918000h
foo_cdda loaded at 08840000h - 08875000h
fooid loaded at 08420000h - 0843A000h
foo_biometric loaded at 083E0000h - 08417000h
foo_musicbrainz loaded at 08310000h - 083D3000h
foo_enhanced_spectrum_analyzer loaded at 082C0000h - 08303000h
riched20 loaded at 7AC00000h - 7AE2A000h
msftedit loaded at 08280000h - 082B7000h
wsock32 loaded at 69180000h - 691A5000h
nspr4 loaded at 08040000h - 08071000h
mozjs-68 loaded at 06B90000h - 08038000h
foo_spider_monkey_panel loaded at 06920000h - 06B89000h
foo_run loaded at 060E0000h - 0611A000h
foo_albumlist loaded at 06090000h - 060D7000h
foo_playcount loaded at 06060000h - 06087000h
urlmon loaded at 05DC0000h - 06054000h
propsys loaded at 69940000h - 699AA000h
windowscodecs loaded at 056C0000h - 05DC0000h
usp10 loaded at 056B0000h - 056B2000h
dwmapi loaded at 6EC40000h - 6EC5C000h
foo_ui_columns loaded at 053B0000h - 056AC000h
foo_multisource loaded at 04990000h - 04B20000h
foo_input_monkey loaded at 04950000h - 0498A000h
mpr loaded at 70940000h - 70994000h
wininet loaded at 61940000h - 61B3F000h
foo_uie_lyrics3 loaded at 04890000h - 0494B000h
foo_converter loaded at 04400000h - 0448A000h
foo_dsp_dynamics loaded at 043F0000h - 04400000h
foo_scrobble loaded at 04320000h - 043EC000h
foo_discogger loaded at 04160000h - 0431A000h
foo_masstag loaded at 04120000h - 0415D000h
foo_wave_minibar_mod loaded at 03E70000h - 03F11000h
foo_dsp_dolbyhp loaded at 03C40000h - 03C64000h
foo_jesus loaded at 03A20000h - 03A3A000h
foo_stnaa loaded at 039F0000h - 03A1D000h
foo_r128norm loaded at 037C0000h - 037E8000h
foo_fileops loaded at 03780000h - 037C0000h
nsi loaded at 6F480000h - 6F49B000h
iphlpapi loaded at 61500000h - 6157A000h
dnsapi loaded at 6E4C0000h - 6E4FE000h
netapi32 loaded at 688C0000h - 6894F000h
msv1_0 loaded at 6D880000h - 6D8B5000h
kerberos loaded at 65F40000h - 65F65000h
concrt140 loaded at 02D10000h - 02D7E000h
winex11 loaded at 02A60000h - 02AD7000h
secur32 loaded at 02020000h - 020AD000h
ws2_32 loaded at 6D780000h - 6D808000h
jsproxy loaded at 68080000h - 680C4000h
winhttp loaded at 69600000h - 69700000h
oleacc loaded at 637C0000h - 63881000h
bcrypt loaded at 66240000h - 66283000h
crypt32 loaded at 6E8C0000h - 6EB95000h
gdiplus loaded at 01DB0000h - 02012000h
msimg32 loaded at 70E80000h - 70E94000h
msvcr120 loaded at 67340000h - 6763A000h
msvcp140 loaded at 62300000h - 625D8000h
winspool loaded at 663C0000h - 66472000h
comdlg32 loaded at 01B90000h - 01DA7000h
dbghelp loaded at 6FA80000h - 6FCD2000h
imagehlp loaded at 6DB40000h - 6DB72000h
shared loaded at 01B60000h - 01B81000h
vcruntime140 loaded at 70240000h - 70255000h
zlib1 loaded at 10000000h - 10017000h
oleaut32 loaded at 64EC0000h - 652BB000h
shell32 loaded at 00EB0000h - 01B58000h
uxtheme loaded at 68700000h - 68791000h
shcore loaded at 63BC0000h - 63C05000h
shlwapi loaded at 64A40000h - 64B2A000h
rpcrt4 loaded at 62FC0000h - 631E2000h
combase loaded at 68500000h - 68640000h
ole32 loaded at 00A40000h - 00EA9000h
msacm32 loaded at 6A040000h - 6A0A2000h
winmm loaded at 008C0000h - 00A3C000h
imm32 loaded at 71200000h - 71255000h
win32u loaded at 66B00000h - 66B69000h
version loaded at 63480000h - 6349B000h
user32 loaded at 6ED00000h - 6F25B000h
gdi32 loaded at 6C9C0000h - 6CBE0000h
ucrtbase loaded at 70B40000h - 70E13000h
sechost loaded at 6BC00000h - 6BC99000h
msvcrt loaded at 6A280000h - 6A4F4000h
advapi32 loaded at 61740000h - 61836000h
comctl32 loaded at 6CC40000h - 6D0BC000h
kernelbase loaded at 7B000000h - 7B4D2000h
kernel32 loaded at 7B600000h - 7B757000h
ntdll loaded at 7BC00000h - 7BEAB000h
foobar2000 loaded at 00400000h - 0067A000h
One thing I noticed:
To do this test i split the tab in two SMP panels to add playlist tools. This new panel crashes even empty with
Error: Spider Monkey Panel v1.6.2-dev+7c0928bf ({245526F8-C8F7-4BEE-B306-90AD014DD52D})
GdiDrawText failed:
font argument is null
File: <main>
Line: 65, Column: 8
Stack trace:
on_paint@:65:8
This means that the bug is present in Spider Monkey Panel v1.6.2-dev+7c0928bf too?
Setting the default wine font to Segoe UI works as intended displaying the ""click here to open the editor".
The playlist manager crashes with
this.g_theme is null
File: buttons_panel_xxx.js
Line: 119, Column: 5
Stack trace:
themedButton/this.draw@buttons_panel_xxx.js:119:5
drawAllButtons@buttons_panel_xxx.js:165:30
on_paint_buttn@buttons_panel_xxx.js:186:2
on_paint@playlist_manager.js:263:2
and buttons_playlist_tools.js crash the player.
