Topic: adjustable Foobar playback speed possible ? (Read 7799 times) previous topic - next topic
I am new to this forum and Foobar. I am wondering if there is a way to adjust the playback speed in Foobar or of there is such a plugin for this. I did a search but could not find anything.
Re: adjustable Foobar playback speed possible ?
This component might be the one for you: Effect DSP. It does have pitch shift, tempo shift and playback rate shift.
Many Thanks for pointing me to this.
Hi
i'm looking for this component ,but can't find it anymore
is there a way to use it on new foobar version ?
or at least I could use an old foobar version with this compontent
thanks
... not sure why it's not available officially so definitely use it at your own risk,
It used to be, but the developer had to give it up due to health issues and could not offer support for it so he removed it.  It's a wonderful plugin and one of my "standard" components.  You can see the large discussion thread on it here:
https://hydrogenaud.io/index.php?topic=84544.0
Hi sveakul
well , I would like to have a healthy component ,because often I like to transcribe a solo slowing down the playback
I could do with audacity , but with foobar2000 it's so handy
thanks
FWIW, the last version of foo_dsp_effect that was actually available from the normal foobar plugins repository was .43, dll dated 06/24/20 (531,968 bytes).  When the developer posted his final binary at the link given by 2tec above, the dll contained was dated 09/19/20 with same file size.  There is no indication of changes (as in a change log), but changes were discussed at the very end of the plugin's discussion thread that may have been incorporated into this version.
If anyone wanted the final repository copy, I have attached it here.
Anyway to get this in the Mac version? I really miss it on Mac OS.
