An update, using fb2k with the FFmpeg wrapper, I was eventually able to get DASH streams playing inside fb2k (albeit transcoded to 32-bit PCM by the plugin which seems unavoidable) by adding a a DASH format with the file type mask "http://*.mpd;https://*.mpd"
Locally restreamed streams via streamlink still behave oddly with fb2k. 1.6.2 gave up after an initial connect but 1.6.7b5 seems a bit more resilient but still takes two tries. The second connect attempt starts playing very quickly after the first attempt expires. It does seem to be opening a new connection both times.
Some wireshark caps from loopback, streamlink invoked with:
streamlink http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/dash/uk/dash_full/aks/bbc_6music.mpd "best" --player-continuous-http --player-external-http --player-external-http-port 8081 --http-timeout 3
VLC v3.0.14 (after 10-15 seconds delay):
GET / HTTP/1.1
Host: 127.0.0.1:8081
Accept: */*
Accept-Language: en_GB
User-Agent: VLC/3.0.14 LibVLC/3.0.14
Range: bytes=0-
\X...9...V.2Ui..........J.u
M[sN..:..U/[.....Z......WU.~....(..H.. .0VX.......sP.H$R..f.........S..+...F0..Q.y]...*Z3....!.T...D..:.D{W.".
...{g..n.x..i.g.~..j.s...d..t.\.*t..C..0.q.s9m....+.....03.....\.k...q^.c...x ..(..."'`.......@!%.....&.$.d..q..@........~.&..ubU..=\:...`........R.;. .d3.P....$.....G..9*b..,..LA
.p.Jm....7
.-k
.........<.<....?...<3...2(...P6F...?.......?..-..M.jH...!..\B..L....'...$....+..D..."...`wG..RVK...J..,a.<...-dm.%....x...C...V.8c..2D.M........:^h..i.."c.|?....DY..8.ap!.Iw.CF..m...N$...I.t.7.#.o....;.+.&B.....D....Nv..'<...*....z.J
L|..O...Gyw.=..=..}.......'._...2....".L...tKw.<..bdQ ....}.;.K.r..c?.,./.P...".......n..:..(....XA ._....".9F..w.s.....
.>.o.j..~#...7\..... ...>Y....U...
../.D..4..5.q........k.....,..<..f.>w.."(.NK..;"
...@.tC........\s7....\^.u...i.g...:............... W..t...}..
.Rz.. .5.....&..{..<kJ....4.....E...?.. ....W`JQ...6....q.0j.r.....2.~u...xW`...8.e._L..0[..p.
....f. /..............#<..........U....OuY5......v..L...{..J.........60
M.F.K..2m....
.k.
.A....f..F5...S...P}.....qQh...@S.4:.......H.....F.2..v...B...........w'
.N.Z...0FM.F.T..x.e W.dB/6..7..7.k..Z......p.>..o.d9!.O......v.....U.D.....r.9.....Y..e...x..V. .....%..qS z.9../.:d.G.l.N..o...=._.+....9.....%>...C...........R.....,F....U.x4...y8.....M..b.
;..dV.....M..X.+.[s.l....,}...;.....L..F....R...z%...3.UM.eL.....$x...N..2..../...C..Y..`{....C..Th3b..5..v{....5/....;O....Rp..H..'-. ..K..1.......
.......?il2...............=L/..?...n...f..K.
(etc.)
fb2k 1.6.2 (after about 30 secs, a timeout)
GET / HTTP/1.1
Host: localhost:8081
Connection: close
User-Agent: foobar2000/1.6.2
Accept: */*
Icy-MetaData:1
HTTP/1.1 200 OK
Server: Streamlink
Content-Type: video/unknown
....ftypiso6....iso6dash...(freeUSP by CodeShop....................=moov...lmvhd....................................................................@...................................trak...\tkhd........................................................................@..............=mdia... mdhd....................U......2hdlr........soun............USP Sound Handler.....minf....smhd...........$dinf....dref............url ........stbl...[stsd...........Kmp4a...............................'esds...........@.......U...............stts............stsc............stsz................stco...........(mvex... trex............................moof....mfhd......>j....traf....tfhd...*...............@....tfdt......F...0.....trun.......,.......;...T...Y.......^...z...3.......M...Q...............(...F...I...x.......{.......-...j...~...z.......Y.......%...G...F.../...I...U...V...m...f...........u...:......./...=...[...O...c...........m...R...*.......n...$...s...........*...$...0...V...f.......:...9...........}..."...................,...O...V.......H...0...........=...1...<...............9.......3...V...U...U...]...Y...a...e...Z...e...........A...{...s.......2...............?...Z...\...^...a...........7...R...S...I...T...J.......e...d...K...H...4...H...........:...F...L...........Z.......$...>....... ...*...M...\...I...k...\...H...B...Y...Y...P...S...\...[...[...T...T...~...S.......t...7...[...........T...2...T...X...<...9.......w.......*...O...@...S...............`...V...^...w...v...............;...T...G.......................8...T...............2...B.......V...U...U...W...U.......)...I...R...\...R...F...P...u...\...........`...l.......?...................q...g.......2...6...0...U...]...[...s...l...q...K...........@...?...J...Y...U...z...k...p...$...6...S...@...O...........7...N...Z...S...J...Q...R...G.......L...A...R...a...I...........J...6...[...k...O...X...........2...T...P...X...T...`...D...............8...V...U...^....mdat!|T..,"....ry.R.$ArK.p.;.......pqPK..F.*,V.:..<q.8.D$yn(.*...`2.bP..#3ZG.U.<.D..<..y$.j.S.........T..y.S8n...b ./.r.0".@.Ex{...fF....w..$.`...i "....".Ff-`2K7...88.-....`.q*{..0{.J.........n...}_L..r.".@... .r.x.Y.
.Y..- `..._].v>....:..M.G..i.^.{..t9..`C&pR..?`g.....Q2..C...K.....DA.....p-@..pwS\.J.....&.....x
......R$....}...|.,.rE.M....'(O.......:.W.{.......*..7.J............L.7.....T.g.......}aE...$ec...C..rC.....o...............;.........?=g.1WA....ZC...\.r
..l.D.......D..wV........z.U..J....6.l......Q._'.xEL....F."/0.El-{.%1z.......A.K.v....g.i...A.b..^..o.M5....F....|....|..H.&...4o:wJ...*.#S.......O ....fA..D@@...{r...U.. .
MB....M..9_..^#.x.a.%.?.....BK.....3.Z!N..8.8L..dr..^D?5E*..j.....3B...T.M5..i..x. .
..U.k.?C.o.=....N.....k^.JZ.-...BX..).)\8.....K}....*........3...Y.vW......G.go.6c..ko:...'...am.Le.0.!.T...& .
.|...^...BYv...7.lz.<...\B@..A!,..r&......S..K1R.......M `.f...DgG.......a..Lp......1...9\.......tH,...$."@6...[.;.zsg..[.5.z...kd.Y.'.dZ:..@r..?..9. .V9......Kk.....bf...ph.....O...h........KY.....Y.N.t...P.UZ....]....?.N..
..#....pRL...g.........Y4...Z..I....`x.......X......TX..._R...V0ft...O.y'..U&.......p|?.m.....,...t.........J.)pB.....o...~u..........D........>!....G.$."+'.?.<v.
h,...2.e!.d..<...(q.4/...g..7-...........dd2./.uv..z...A}R.....3..1'c~[..cJ.....P}+./...>...o.D...Av..OaY;. .H.$.yx....2.`.P....w..E...Ke....pX....<...p.l...7p.f......G...m.....m.=kX.8...7.(.`.6...0.>IL...i.p)...k}..M.. &...3o.P..v
......_.t.5.....if. .{......9....S.T..[.
wD...|.K..8...*...~ck..FT3w7.u\..n.........`...5i..tA.....).1W1...r.u.. .P..~)...0F....iC ...L..H...A.`...<...GFw.]_..Ae............[9..C..Z.m..4B.TS......:..f.D!}.#.z..........0..!.T...& ....... JZj.....bm..Jp.`....H.T(#...e.a!)..t.wN$F.(.=ZM....i.h$.d.tF./...s.I=.+.~.`P... !.n.......R....@..+&.O=k.[i1..%@..mQ|....)..M.L|,.J..b...&.L...j. ..a.#.. ..DJ....fm.l..k.....<..UT.wM............/.`
..o.......]..6.^I..;.:..
+........F,...GP.Z]j*.DR....w....`..kx2...<.t:l...L..k.>.D.....r(.n.MQ!.k......&@....n6...v...(.[s..OS....pD......%l
..R.#)&........P........j....<......@x.?..A.P.....1.a........X.^..%....}.Q.....:..E....|Gh..'........R.c-"....l.z-.........!...[..;...#..*!.....6......:...\.........S.....T5(I$\..`*~.....V..S./..'..;3.x...n.?.....-u...O..@3.`..
..pA..".Z;....!4.....&~.H..`J4....!............;.'.k.\....Z#.X.y.F;..o.zm.Y/%..e....A=...-......L}V...ew.}.yy..=.)H..LG$s.bX.........e...G....r....J0.Z..,..i..;...E..I....0..N...5.X.....
....L..x.o......\j\
.).).C.7...K.Y.S....'..:.(...*3....Wx....;
..2.i....._>9....&.K .!.O......R....D.,..}s..V.U.[Wp....0......]......'.....#.dT.x.d:YT$..t.F]>...qc.. ...*..........D..I1..m....!...A'..G...hz....~+..5L.....*..!9....d..F....
9T..m3].$B]...._..Q..tU.L.LM...+...Y....B#...a..+HTR......H .....=HKM....$.+=.[)
Q......M"!..._F...Te...H.>Og..
....^.w.-....xQ_..C&.B`Pu..q.G.....s.gvW..z?....`fQ{>.;....}J_'.`......yP...sg6M.`g....q.W!..f
G.sg.p..X(..@-+|.PpiT.X.s.z...r...j6..G._... .....*..4[.;.=.t.....t....c.<*.n....Z....uG.2.<4...... ..T..-../...........j....).j+....
(.J8..:..@G....)...........{L...Ivp6_.H{B..........`............H......t..6V...z..$.f..I...}..v..q.*.>.....I-.2T.......2...#.M1..`[........]..rn..a..p$..B.:k...=.V(...b^.fo.S.....||k....n.....Yt?..[8;...X&P.@.a..}.)6e...s.#..G.....0..sJ...%.6%.o.!@....Z..MO...x....3..`$.............RQ^.........8j..k]{.(..&"!....7.Z.^Y..../8:t......"...&..de.T.i..F.....W..`...".D4.}w.X....3..............G
.b).J.V...o.].7$.....b...UR.=...........jl.....>.3.........p..9.nL.!.T...& .....=.J.Y*R.......n.}R....2K.bKv.........%..."&"E?..r.)..$;.y>.b....jj...l.4_...d..5.....Gct..+.D....HmmS...... :#.7..8}.}....@.a........F..W)...........PwQj"..r.d.8z...S|...?....-.....c.?..g..FH....~u............#.M'.g<....<....r.u?Cn.V".x...').............-.(.....u..%....I.^.6......G...%.....O.../-OTPc.8.C._5J~..u..w...i.W..W.Y*B.w.j,....K....].We......1.E.d..l..u...Q....G.Xi.J.&b......o......:.,...k9|w.o.s.+......1k.n.f:.v..zUz_Z.;.Ua.......4...&..7.7...z~.5.-sl6.U? .X.%..2.7&..9.Jf..........n..v.5.:.y...Z ..&..471a....a.+K....
.L..[m.... .s........l.V.jd....K..;.........D...
n.....E^..us..d0v...4L.'.UT.Lm.t.r]...1..z|.....H.....o.[...1...'o.....z..W.Zj.m.{...6..5#.4.K.....4.L."&
(etc.)
MPC-HC (after 10-15 seconds delay):
GET / HTTP/1.1
User-Agent: Lavf/58.68.100
Accept: */*
Range: bytes=0-
Connection: close
Icy-MetaData: 1
E.B.Ks...H.C.......
?.F
.[.L.Y../.......N..\X.6n{T..t^D..7...+C$LN.}.A.....R......LE.A.z.y.U..*(.c.j..[2....w\-mq..n3...zh...Rs..G...qUb...w!.T....".F.hQ.....xy...}T..|..iH ....u>M
.>|.N(....EQ 2w.............:.ozfB.. ...H......V.p.....Y..Nkp.5y<Y...X.
../.....:C....%.
......X..&.v_X...<<...h.{n.........\.R.hU;..l..HD.?Z...M....s.s<-......1..y....'.A...r.sO...._.}..)|.....S........[&..7.#R..u.......o^..$.d.n@......i_..pj.vsE_.'
....)..+..O...$.N.T...._....D.u..
........n.....)t,{|}!../
..&#g.o.D.{8.`.....m.z..m...$Ow'.;.*kr\......c
.......]zv..v.^: ...z6..R.T<..oD..z|..2......~....k&.C.:..4g..R...$..RlI..M...}u.|..j..o.h.{.....B..uB.%B.v.i..]..4S..........8...3..8...].....U.. ....a...,4... Y.......~........2...@..H.....d.)../#..sg.%...}
_i....X0.....T!U,.f.L'
...4Q...D'....U'.O....6K.~.| &.>....c5..l....xdm....rP.F.G...h...L..FPl.J.`D.....-.;v;..m...E.Q.0..K....T....{...Z.i8T .. .eA|..E.AU.]w......o}<.....@.',..i..$.....g.p...AX.2D..
.......o.B.........P..[..u.f.!.T..T.2.
i.:.................\...u.F..qu..L...IQ . %.".y 4.M)........D.
.B.4.p....:Ca.%@v...^.{.Pq3...F_..Sv.y%.;....Rh.....8... (..."PZ@.g...M.........i.?.A.t~#.e.0...?.j.
..x..._......n...Kb.q;)....K......Ly..u..q..]....U..M..mtv....'.X.+kq72.K..r....6...PM.9.....`%..k..5..@V..0.'....4/<p.......-...$x...@..d.l.l....t..:o_.......j..T/...^.S..J...j.....r..3'....c+......TB.&h.......Tnt.v.R....._..v.wI...).Ah..B@...-.....0..b..n.Tc.#....7..;]..5.......:...f...h.
&3...?.....o.l.Qdzw........qy.C*.'.88.... *.R3..f../4~G..a....a{Ng...X.`.*!.K......P.6...*W3k../p\..7p..`lD($.....:.j.....9i
.f..r..nd!..kb'.).....g..|.V........N1F6..j4....+B...6...:...F6...._..dv;(o:!C.T.M+.c2lF...by.....j.....z...M..9..mu.i.r..)....;S.8.1IN..#.E9.L..7.H....-e..s..E..f..N..1..y...P.A<.)..xuA.*.}*.......4.N.H.T... NW.!.j.....
0F.9..c.o ...4U...t....@..~$..|.0F<$.....!.T..P.2..t.....t.....].z.jk.x...$(.#..fD....l.B1:...BD.9.Y6..S.$.......... e......?.....)Yt.?QeQ..y.... &z..PF..S"`Oq.gq...^.._.n2....$L......3........)t~I...b.?uc.................x6.j.=...N)(.....J...J.&.s}j..uNt'./..#j.>..w.n>..4..V... ......I.....p.#VLQ....JF... .(s.6r....#e...#/d....,.).$......;....e...3..p......Ev1%3....w...........)1..........|.....i....y4.P.~b.%.,.n...$j.1k5fg....>+....n?<WH.$LO.`...a.Kd...t.-9a.e.4WI...9....VR.z........OP".7xArZ..$d..............`..........#x[#..9..Yo.+.X......c.Q1......A....E......-....UU.M6^I.=..g
.?...Y.^3....'3T.N[h.8....`.A$...O._......{.'.....^...H....?..-XLL..7;..n.V......$..n...6g....'H.Y.!......K..C%X...]..}Z[..R.`..d.Y.v....
.>oW.F0. ..".H.....u..<..:S.y.....`....!m+t.w....
.tj..M.\.....9.....*..I..g.p..D..3.{D.mED...a.w.OB..;...C....J..,.....o..~O..ec..,.....>V...D.k.#v;.!.T..(...%.C........o7<.......w.^.5{.Y..m..(. %J.(3.$%..9.tL}.v..g.uI..F."`}.Q..\.G......z.=.h..COpL.:..k...3....L.};s.:..s..^..7>.b...$b..... .dnZW....e.......>.i.....*.5....N.......+.Z...;.?.gEK....}Z...........)......L...:.I..~{'......S.m......H....Y.............z.w~L].>..d...K...........]...4v....@.D....{.4.Z.......6....i...v..J .........~.3w'.......Q.@....M&..r.....9.%KbQ......}9r.x.A0.%s..Z.D.
.-...M..N...!..mrf7......s...~.[..
(etc.)
fb2k 1.6.7 (after 10-15 seconds delay):
tcp.stream eq 66
GET / HTTP/1.1
Connection: close
User-Agent: foobar2000/1.6.7b5
Accept: */*
Icy-MetaData:1
9....1Pa...B.%...[.CIZ*b..{...O.g.|.._......b-...~..B..[3..N...o..,...m._.=N..........fA..j........Dl...
... ..3...q.f....).54."R..%.\~^...'.!.O......r........m4.AR.%g..q2.....'/..urP..f.._..;.....\...=yR..........L..u.^k...Q.?v......!...1Gi.......4G......9...n%...[...[.{b\...[..fK.nf.w.2..S...^.....C...J...w...yq!..T...+5.Y{.Lp..M..x.Lp.
J.7....!...N.......Y~#r.<..x>......{............$......<....-.A.6v`A7..imC..7A .OD..#.c....o.U..^..LR...jt...1....)..g0.X(....S....,...o
.9.'.z...
..&.br.~.Wr......@...u(.....u.w=A.j...s9.....r.R....KP.......c......R.$....6.3.vT...Z.r0........,4.j..9S.......v.b...<.l.vI....P.........a....$..j.K....V..
..|..*..Z.".++.js%.......QF.vv'.....T@x.J.X..S.qu......n.....>...#.-o[.X.....'.......}..T...j..j..j...k...)D.r..@.K...../../..w.WZ^......d.H.
N."..F!..s.V.&....c.
.Ol...i....[N.7.x.9M....\..g.3-.....{..?..zU.......>f.....U.
1.XY....._...wO.j.P....&G...../....W.MM.Q....C
r..!i.y7%...E@.....j...l..T#`..;.)...6S..2I...9.=.US&H%T...R.M..f.F*D..~,..t.{...a$.,m....(...v..{....s Nh.!.O......f.
........T..y...\..)2...eHe.$`......E..?.<.YQ.J..I.....*.MS.e...g...k.x....#......wV..Z...Cp.0O..^u.^..=...C5>sM:.M.Wl..XH.$g0.C"m.....9.....o.....A...\..h....ng.d.v..b..q....6ySl...6...`M....[.?.v..<_9"6rb.'~.d\.....n..S.B.#.p<rs?j..y...~q...T}.vf(..^.@...#}.#.s$.yu...3.".......2VF.........3.a.<.kW.q_..t......!{.....Z.....9.K].8..nNR...j.)s....q.....[.c8Q....J .>..5....Ug}La....W*.\......"X..U...l....k/!?.4.o...h..XL*....2.Ri3G......Q.Fd..2. W.Y.~Y..;r...j.K...T.......fN.M.i..f.T..5V.Y8..o,. u|k.....~.\u.f .#...7.9.P..{...{....#LQ..
..,W=...... .....8.....%#`..e....o......V&......4...y.w...{...7..+.Y.OH...p.<......u..Z.k....1..=..........0... ..T.$.._....".\...
6...C.v.......Zj9.wD..z.8U.T...FD....kw,..!......xP...m.......G,..5.Hs.....+..9.krf.
.......<*....oN..
_Gl.yr.l.kf...
....[Sf...D.... ..H1.!....).pq.4.9.G{u.\....$u}.._:..J....$..;.*.y..z+.5.q....w..!.O......v.I.Q,4+
....)..nF.....R...S`.x.4._.&...,.D..e.,I....J{....~-.y.b..q..(e.../Y..z....U.<.G0|1h....h...m.yYo..)....epF..d..l)..g...u.......s....U. .....@............aF..|...-..6.x.l.....b....d....E..F
.ql
..R.a.........:.....3.uM.a:..9.C:.<]@..,..3...W...C...v}+
(etc.)
fb2k console during playback attempt:
Unable to open item for playback (Unsupported format or corrupted file):
"http://localhost:8081/"
but almost immediately after:
tcp.stream eq 93
GET / HTTP/1.1
Connection: close
Accept: */*
Icy-MetaData:1
N..Hl./.{...C..^.......|Y......
.3.....Rw..(lL.^...._..pP...
.,w]F...n........]X....C:..4.L
r.0..sM....YwL...e.".i.........,....o..).T.....r.M. ....:...}.s..TL......@..n...0sG.?._Km........_...X.......G...h....tlKt|.(
.'.}{....xo.^..388......LPCXX.........}..K..T8.
..c.A$.oq._./..8}s........A....o.3...cK..9..~.....&T..<......... 8..g.HH.R*.u^i'....'.y...4.."...4.....W:..@_3r3<..Tl..rB
.....{EV.. ...[ $.j..??......;t.).....;F..e.o.w.#...O......7...T.*.j...-."..Sy.LT.U....^...B....!1*lH..OP.R....5..a..M..j&.
,2..091.d.P.K**....5...U....[4.C...^yW.........@...T.>gr.......................!.Oo.....f.z..............y.z..z.ko.Q.I.HO1'*D....}..M....... .b-........N*..!|....)...&!.k....#l.O.r..<..-....f.b.'.....amx.).!.Y.qc=.....8..M...E..q..5....G(..E....k7#.\......c....2N.Z..U..*.......vN....pw...V..<6.y.I].t.ZR:......$..6l.`.g.?8....Q..=....rb....c...s..+..5..-....QI..+.
.j.396>..Q..{p?:.......{R.......%H.1..... ........n.<.G..A....w.
7.yhT.5./-{.z...H....Q.q.X...v.......yZV<...X..2....!.4.e.C.( .^.c...
zMC.m.....5.d...h1#.k6R.rM....].u....
M.[.[...d...........-m..2.......q(.l...A8...7:..i....v.S.
.A`..(1..>..R.N..W......=...r.
.....swaW....y..q.....R..\..........h.h.S3w.C]
Z..'*..YR...fa.oF4.._...ZJ.Fc..@..@..~'I
..:.C.*.&<zK..2.....h.....v..6...M..p...............Ae4.r..0.]V-n.7.l
.eIy.c.)Z..sZ..1.....3sR;.....kE...J DZ.B.........|.=...-dA...@..Y+Ml.bO..o.......n...9.s..}..%z.G..n...._.o....................................!.Og.....V.z...-E.=../^|/.i...8...Y.1..N....O..4.p.6.-......@.".v.1Z. .V.$...O...i.......k...O..=..~..%..f.T.Q..m.4..........NA!"......[&O .`8..cC..q[.w.}..^W...0@..S.&t...... ..3\._y+.L...u...4@.o.Q..l1.N0....@Qlc...{..J.3?.P)......../..[+...1z..HmL.o...5.Q..u.'...]...,G..e..E....[.{m.......Z.....t....b......L.X......<.h.t....cA.M22.b.-N...L......dvo2N....M...0Eu7.u.....E.{'o.]. R....}Y@.f.?.....Ts.............o).....B..\C..)..,. ^.../.$E^....r.:[............aH].!W....a...A}....8%M.*zm......b...?...-.?.V.D.A.L...."..Va...;z|g.....W..^.9..LhD.........1..{..Q+...q
(etc.)
streamlink http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/dash/uk/dash_full/aks/bbc_6music.mpd "best" --player-continuous-http --player-external-http --player-external-http-port 8081 --http-timeout 3 --player-passthrough http
Also tested with
example CLI output from streamlink during these tests:
e.g.
[cli][info] Found matching plugin dash for URL http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/dash/uk/dash_full/aks/bbc_6music.mpd
[cli][info] Available streams: a48k (worst), a96k, a128k, a320k (best)
[cli][info] Starting server, access with one of:
[cli][info] http://127.0.0.1:8081/
[cli][info] http://192.168.2.103:8081/
[cli][info] http://192.168.47.1:8081/
[cli][info] http://192.168.57.1:8081/
[cli][info] Got HTTP request from VLC/3.0.14 LibVLC/3.0.14
[cli][info] Opening stream: a320k (dash)
[cli][info] HTTP connection closed
[cli][info] Stream ended
[cli][info] Got HTTP request from foobar2000/1.6.2
[cli][info] Got HTTP request from MPC-HC
[cli][info] Got HTTP request from Lavf/58.68.100
[cli][info] Got HTTP request from foobar2000/1.6.7b5
[/code]
