Topic: LAME won't encode these files (Read 4508 times) previous topic - next topic
Just ripped a stack of discs with EAC, only to find that RazorLame/LAME will not recognize any of these WAV files for encoding. They cannot be dragged into the RazorLame window. They cannot be Opened, either. I renamed the containing folder to "fff" to no avail (RazorLame has problems with longer path and file names). I copied individual file names into Notepad, and copied them back, to remove any possible hidden characters—to no avail. I cannot rename these files to something else and encode.
What is going on here—every file from a given disc? I've been usiing RazorLame for over two decades, and have never seen this happen before.
One file from another disc was doing the same, but I could encode it after renaming the file. I then renamed it back to the original title.
But not these. RazorLame will not recognize any of these:
01 - Isaac Hayes - Two Cool Guys - Beavis and Butt‐Head Do America
02 - Red Hot Chili Peppers - Love Rollercoaster - Beavis and Butt‐Head Do America
03 - LL Cool J - Ain’t Nobody - Beavis and Butt‐Head Do America
04 - White Zombie - Ratfinks, Suicide Tanks and Cannibal Girls - Beavis and Butt‐Head Do America
05 - Rancid with Stubborn All-Stars - I Wanna Riot - Beavis and Butt‐Head Do America
06 - Ozzy Osbourne - Walk on Water - Beavis and Butt‐Head Do America
07 - No Doubt - Snakes - Beavis and Butt‐Head Do America08 - Madd Head - Pimp’n Ain’t EZ - Beavis and Butt‐Head Do America
09 - Butthole Surfers - The Lord Is a Monkey (Rock Version) - Beavis and Butt‐Head Do America
10 - Southern Culture on the Skids - White Trash - Beavis and Butt‐Head Do America
11 - AC^DC - Gone Shootin’ - Beavis and Butt‐Head Do America
12 - Engelbert Humperdinck - Lesbian Seagull - Beavis and Butt‐Head Do America
EDIT: This may be a case of some asshole entering Unicode-formatted text into MusicBrainz for this title. I had copied my file names into Notepad; was about to rename everything with Bulk Raname Utility, then paste original file names from the Notepad document. When I tried to save the list of song titles, I was hit with a warning about inclusion of Unicode characters being lost upon conversion to ANSI. I just started using MusicBrainz yesterday, which would explain why this has never happened to me before.
EDIT 2:
There was no way to strip Unicode formatting from the path and file names for those WAVs. I had to delete them all, Clear Current CD Information in EAC, manually re-edit every field in EAC, and re-rip. Only then would RazorLame encode the files.
If this is what MusicBrainz has to offer, I'm in trouble.
Re: LAME won't encode these files
Probably the "-" sign. Or path + file name too long. RazorLame is to blame for being lame :D
MBz always uses a weird apostrophe:
Pimp’n
00000000  50 69 6d 70 e2 80 99 6e 20    Pimpâ..n
At least that's what I got from copying your text and pasting it into notepad, then looking at the binary.  I fix it at EAC's track listing.
BANNED
Just to be clear, RazorLame could recognize none of those files, even the short ones. It does not choke on a hyphen—I use hyphens in every file name, all the time. And it wasn't just "Pimp’n Ain’t EZ." Also, I renamed every track to a two-digit number, and they still could not be processed.
Every single field in EAC contained Unicode, as pulled from the MusicBrainz database. I had to clear CD information and re-enter everything from scratch before it worked (obviously, with the same length in path\file names!). Any MusicBrainz metadata in containing Unicode will do the same thing I encountered today.
Still, time to switch to something Unicode aware...
RazorLame hasn't been updated in 6+ years, it's probably safe to say you should find something else.
I've been using it as long as I have, because its encoding never introduces the chirps and noises other application have. What do you suggest I use?
rename all manually
Use a newer version of LAME itself, with something capable of using recent versions of LAME.
RazorLAME is just a frontend. One that is apparently incapable of dealing with Unicode filenames.
... the newest version of them all should be attached.
BANNED
I remember having change the version of LAME used by RazorLame once before, but that was many years ago, and details escape me.
If I install newer versions of LAME, would I not still have the same issue with Unicode with RazorLame?
Assuming something else can do the same without introducing chirps and other errors, what exactly might I use?
Thank you.
What chirps and noises??
You rip with EAC why not setting it up to encode with LAME at once?
I wanted to recommend Lamedropxpd from rarewares.org, which is lame and real simple gui in one.
But i just tested an mp3 with an exotic filename and Lamedropxpd crashed :p.
So instead i will recommend it foobar2000. It is a player and it has a nice converter built-in.
I recently found this post after having a problem with some filenames and mp3 encoding with lame. I am using lame via a batchfile, but the solution I found was to add the line 'CHCP 65001' to the batchfile which changes the character set to read non-ASCII characters.
I was then able to encode the mp3 file without a problem.
