Topic: how extract music files from apk files (Read 8220 times) previous topic - next topic
Re: how extract music files from apk files
You can extract an apk with any unzip program (i used 7zip).
In dragon-ball-z-dokkan-battle-4-5-3.apk I only found one music file called bgm_009.awb in assets\bgm\.
Install foobar2000 and install the the vgmstream decoder by Kode54.
Then you should be able to play the bgm_009.awb file.
According to foobar/vgmstream it is this format: CRI ADX 4-bit ADPCM (type 9 encryption).
I do not know the game, but i suspect there should be more music than this one. So either i missed it in the apk.
Or maybe the game download additional data file. Then you should search that.
yeah i dont know if the sound files are getting by actualization or if i need to install the game in my phone and then seach the files
According to Wikipedia, ADX is a variant of MPEG2 audio. So mpg123 should be able to play the demuxed stream. But it says the file is encrypted and without a (legal) key, your are out of luck. Probably easier to grab the analog signal with an ADC.
ADX is an ADPCM format owned by CRI Middleware, not an mpeg derivative.
My mistake, the MPEG2 audio derivative is AHX.
how i can get the files then? i dont know how to grab the signal with adc
they didnt answer me
well i will try for my own... but if someone can help me it will be great too
You posted in the wrong section, didn't provide any useful information (url, not a single awb file) and despite this you got an answer.
Did you even try extracting the awb files with QuickBMS with the proper script?
i tried but idk how
can make a request? i only needs 3 themes from this game
kid goku theme
title theme
title 8 bit theme
Yes, but that file at least have 3 re-encoding, i want it in his true quality
Topic closed.
korth
