Topic: Settings foobar2000 for 32-bit/24-bit to 16-bit FLAC/WAV (Read 8392 times) previous topic - next topic
Hi everybody, I was attempting to convert a batch of 32-bit/24-bit files to 16-bit FLAC's and I wanted to use foobar2000, but I am having a problem understanding the correct chain of settings.
I choose Convert ... then the Converter Setup opens up.
In Choose output file format I am selecting FLAC level 5...
And then I freeze... :-\
Output bit depth 16-bit
Dither never  :-\
or shall I use: always?
I am asking this because when I go back to the Converter Setup in the Processing option I am choosing the MDA Dither DSP
If I am using the MDA Dither or the Smart Dither DSP for foobar2000 shall I set the Dither option to never since I am going to use a different DSP dither other than the default foobar2000 one to do the task anyway?
I will only be ideally needing the word length reduction function then and be safe in selecting never...
There seem not to be a clear answer on that... and I just have a feeling that the foobar2000 one will kick in in an unwanted way if I choose always... or ignoring the processing plugin if I choose never... :(
Should not be the dither option get disabled when I am processing a file with a 3rd party dither plugin?
Re: Settings foobar2000 for 32-bit/24-bit to 16-bit FLAC/WAV
When you use a third party dither component the built-in dither feature should be disabled.
If you choose always then you would have double dither and the third party one would be essentially pointless.
It should but there is no functionality to achieve that.
Exactly as I was expecting.  8)
I hope someone else might find this info useful... :)
Thanks a lot for the reply. ;)
So the correct chain will be as follows:
Convert then I choose a new setting ...
The Converter Setup opens up.
In Choose output file format I select FLAC level 5
Dither never
When going back to the Converter Setup in the Processing option I choose the MDA Dither DSP or the Smart Dither plugin needed in the Available DSPs to make it Active DSP for the processing.
Then I click Convert and that's it.  8)
Following in @dadadacicici footsteps, I set up Foobar's conversion to 44.1kHz/16bit. However, it turned out either MDA Dither or Smart Dither component in the DSP chain is applied unconditionally, i.e. even to already 16bit files. This can be confirmed, for example, by converting FLAC 16bit to FLAC 16bit and comparing the Audio MD5 tag -- they are different. Question is how to apply 3rd party dither conditionally, i.e. 32/24->16 dither, 16->16 no dither?
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
You have to do it manually when using the DSP manager. It is because the need for dither does not depend on the bit-depth of the source, it depends on the bit-depth of the processing pipeline.
For example, if you want to swap the L/R channels of a 16-bit file then save as 16-bit again, dither is not needed because the only change is the order of channels. However, if you resample (e.g. 44.1k -> 96k or 96k -> 44.1k), or apply RG, or mix channels (e.g. stereo to mono or 5.1 to stereo), dither is needed even when the source and destination format are both 16-bit.
Read the thread below for an example:
https://hydrogenaud.io/index.php/topic,121633
