Topic: Crash in Beta 11 when using the ReplayGain scanner. (Read 1123 times) previous topic - next topic
When scanning a large set of files as an album using ReplayGain.  It's possible to crash foobar2000 each time.
All are FLACs except for one 32-bit floating point wav file.
Re: Crash in Beta 11 when using the ReplayGain scanner.
I don't know if Peter needs them, but I'd love to see the files that make this crash. (Floating point exception, so it's division by zero or something equally annoying.)
You can PM me with the links, if you manage to isolate it to specific files and upload them somewhere.
E: Got the test files. Can't reproduce under Wine. Can't reproduce on Windows, either. Looks like a case of SIMD code path ignoring floating point exceptions, if your processor is old enough to be missing whichever code path this is using here. (I have all the way up to AVX.)
Processor: https://ark.intel.com/products/97123
The stable version of foobar2000 (v1.3.17) doesn't crash at all, interestingly just the recent beta.
I did a debug analysis of some of the data.
This is the code executing from foo_rgscan:
  624DDC37: DD 05 08 B9 03 10  fld         qword ptr ds:[6250B908h] ; (reading: -666000000)
  624DDC3D: D8 D9              fcomp       st(1) ; (contains: 1#QNAN)
  624DDC3F: DF E0              fnstsw      ax
  624DDC41: F6 C4 05           test        ah,5
  624DDC44: 7A 08              jp          624DDC4E
  624DDC4E: DD D8              fstp        st(0) ; CRASH
I don't know what to make of this. Peter will need to look at this now. I'll forward the PM to him.
Got the files from kode54, thanks for the report, I'm investigating it.
