Topic: JScript Panel 2.0 and Powershell to extract cover art from youtube or audio file (Read 2727 times) previous topic - next topic
hi
i there an easier way to download coverart from youtube or extract from audio files to another folder while playing?
maybe someone know how to do that powershell thin in the panel script?
i am using this plugins...
https://github.com/marc2k3/foo_jscript_panel
https://fy.3dyd.com/download/
http://skipyrich.com/wiki/Foobar2000:Now_Playing_Simple
https://github.com/farpenoodle/FB2KNowPlayingOverlay
this is my panel script it triggers a powershell script which is placed in the root of  FB2KNowPlayingOverlay
function on_playback_new_track(metadb) {
WSH = new ActiveXObject("WScript.Shell");
var path = fb.TitleFormat("%path%").Eval(true)
fb.Pause()
WSH.run("powershell.exe -ExecutionPolicy ByPass -f D:\\OBS\\plugins\\nowplaying0.1\\reader.ps1 \"" + path + "\"",0,true);
fb.play()
reader.ps1 powershell script
$ErrorActionPreference = 'SilentlyContinue'
Import-Module BitsTransfer
Push-Location $PSScriptRoot
if ($args.count -gt 0) {
remove-item "$PSScriptRoot\images\1.jpg" -force
$path = $args[0]
if ($path -like "*youtube*") {
$ytID = $path.split("=")[1]
$output = "$PSScriptRoot\images\1.jpg"
$checkURL = try {Invoke-WebRequest -Uri "https://img.youtube.com/vi/$ytID/maxresdefault.jpg" -Method 'HEAD'} catch {$false}
if ($checkURL) {
$url = "https://img.youtube.com/vi/$ytID/maxresdefault.jpg"
} else {
$url = "https://img.youtube.com/vi/$ytID/hqdefault.jpg"
Start-BitsTransfer -Source $url -Destination $output
} else {
.\ffmpeg.exe -hide_banner -loglevel panic -i $path -c:v copy "$PSScriptRoot\images\1.jpg" -y
Pop-Location
also tried this solution https://sometings.wordpress.com/2016/11/17/executing-powershell-encoded-within-a-vbscript/
but not tested much because jpanal crashed everytime :/
kind regards
beth
Re: JScript Panel 2.0 and Powershell to extract cover art from youtube or audio file
2.0 is still in beta which might explain the crashes. Did you try 1.3.3.2?
it works but its a bit slow. i am not familar with vbs (wsh).
ihe solution in the last link is a bit strange because you translate the wohle code in a short string and execute it with powershell.exe. i dont know if this works in fb2k wsh :-)
my intention to post my code was maybe someone had an idea to do this in wsh without powershell or somebody know another method to extract the coverart while playing to another folder that the OBS plugin cann grab it an show it in my stream :-)
You'll never be able to do it in raw javascript which is what JScript/WSHPanel uses. There might be a method without powershell, but I don't know what it is.
