Topic: Horrible sound whenusing: Convert St to 4ch + Graphic Eq (stereo) (Read 615 times) previous topic - next topic
Horrible sound (as if it was over saturated) coming out right speaker when playing stuff using Convert Stereo to 4 channels and Graphic Equalizer together.
Only happens if Graphic Equalizer is in Stereo Mode, and if Convert stereo to 4 channels is applied BEFORE Eq.
(Obvious solution is to convert at the end, but accidentally changing the order can blow up your tweeters and ears.
