Topic: Lame 3.100 has been released (Read 128810 times) previous topic - next topic
Re: Lame 3.100 has been released
Here too, much faster: http://tmkk.undo.jp/lame/index_e.html
with this patch applied, i get an error when i try compile x86
./configure  --host=i686-w64-mingw32 --enable-shared --enable-static
and then "make -j2" leads to a
gain_analysis.c: In Funktion »filterYule«:
gain_analysis.c:216:5: error: impossible constraint in 'asm'
     __asm__ __volatile__ (
From the RareWares 64bit build:
OK, thanks, I'll sort it out.
john33, perfect thanks, let me know when and I'll test right away.
Do we have listening tests yet?
Reply #30
Corrected compiles uploaded. 32 bit and 64 bit versions tested on system without the Intel libraries present and load and work fine. 'More haste, less speed' called for, methinks! ;)
Very good and almost as fast as tmkk (~55x vs ~60x), will test more tomorrow.
I don’t know how he compiled, is there any reason we shouldn’t use tmkk?
tmkk's binaries aren't just a different compile. They use replacement functions that are faster but also produce different results.
Reply #33
Sorry for the absence of compiles on Rarewares, but I have been away from home for the last 2 weeks and I don't return until the end of this week. I will post compiles as soon as I'm able. :)
Thanks John! Can you update the libmp3lame (x86 and x64) compiles too? I might be the only one using them, but I do use them!
Could you kindly check these compiles to see if they are OK before I post the links at Rarewares? TIA. :)
libmp3lame-3.100x86.zip
libmp3lame-3.100x64.zip
Reply #34
@john33: thank you for the updated flac and lame versions at rarewares. will there also be a latest ogg lancer build as well?
Reply #35
I see "LAME3.100".
I get additional special characters depending on the encoding mode. With CBR the encoder is said to be "LAME3.100Í" and when using VBR it says "LAME3.100Ý". With Lame 3.99.5 I don't have this "problem". I tested all encoders from this thread. Can someone confirm this?
Reply #36
You're welcome. :) I may get round to the Lancer builds, but I don't believe the code's been updated in a long while, so I'm not sure there will be any benefit.
Reply #37
d4k0: That's an innerent problem of old programs assuming that the tag was going to be 8 characters always. The problem is that LAME3.100 is now 9 characters, and in C, the strings are terminated will a null character (code 0). Due to this discrepancy, now the string is not being terminated at the correct position with programs that didn't get around this possibility.
Reply #39
hm, i think there have been some minor changes (not qualitywise though) to ogg lancer indeed. anyway, after flac & lame it would be great to see a lancer update, too :)
Reply #40
All builds sometimes create different files, even the x86 and x64 version from the same bundle. From the null test results I am unable to tell which particular build has more differences than the others, plus I can't ABX them. Therefore I am going to use tmkk's version for the speed.
I learnt about the term "non-deterministic" in x264 but I think the situation is a bit different, since individual lame.exe always create identical mp3 files.
I wonder will the same lame.exe create different mp3 files when using different processors, like Intel vs AMD? Who wants to try?
Among the attached files, Rarewares-x86.mp3 is the only file which is different from others. However, if the original audio files are longer, all files are more likely to be different.
Reply #41
Confirm Rarewares-x86.mp3 is the only different one with bit-compare.
Reply #42
It's been discussed in detail before, but basically floating point numbers have rounding error, so each of the many ways you can compile a mathematical operation may give slightly different results due to how the numbers round. If you need deterministic output, you're probably looking for a lossless codec.
Reply #43
sorry i was wrong, it does work, i simply made a silly mistake. :(
Reply #44
"Different results" as in different from all other builds, or ... ? What exactly are the replacement functions in question? Maybe I am just dense, but this thread has taken a turn toward the confusing. Or rather, I am confused! So which is the better choice? The tmkk Windows build or the flac-1.3.2-git-20171020-x64 build available at Rarewares? I am just trying to follow all of this and am obviously failing.
Reply #45
You're even more confused than you think. LAME != FLAC. One's an MP3 encoder, lossy by definition, the other one's a lossless codec.
Reply #46
Aren't i an idiot?! Shows you what two hours of sleep will do! I meant to say the rarewares lame3.100-64 or the tmkk build.
Sorry about that!
Reply #47
Unless you need to encode a lot of music very quickly I would use the standard lame builds.  The difference in speed is not that compelling on modern hardware.
Reply #48
It is not difficult to sleep 2 hours a day. It's difficult not to sleep the other 22 hours :))
Reply #49
Nice one! Thanks a lot for all your hard work on rarewares, @john33
Edit: added work (oh, my!)
União e reconstrução
