Topic: Burrrn is buggy in Wind 10 64 bit ? Anyone using it in Wind 10 _x64 ? (Read 3243 times) previous topic - next topic
The ExactAudioCopy duplication of CD s to FLAC via its non - compliant cue sheet format is excelent .
I have used Burrrn for some years as my go to CD burning software ,
however , it has not been updated since 2006 . Now it is not stable in Windows 10 64 bit for me .
In Wind 7 64 bit I never used the Settings > 'Raw driver' , now in W 10-x64 it says that it wants that :
[spoiler=Burrrn log]
Finished processing file #19.
Recommended Album Gain: -6.63 dB Scale: 0.4661
WaveGain Processing completed normally
Initializing SPTI ... OK!
SPTILOCK:1,0,0
SPTILOCK:1,0,0: TSSTcorp DVD+-RW TS-H653J        Rev: D100
Starting write
Starting write at speed 32...
Turning BURN-Proof on
ERROR: Cannot set write parameters mode page.
ERROR: Cannot setup write parameters for session-at-once mode.
ERROR: Please try to use the 'generic-mmc-raw' driver.
ERROR: Writing failed.
[/spoiler]
When I go to Settings > 'Raw driver' & put to ON it still gives problems ,
it wont let me burn with that on either .
I have to start Burrrn , then Set the 'Raw driver' ON
try to burn (get above error)
then turn 'Raw driver' off
finally it burns , but without CD text in the computer drive .
V for Vote
Re: Burrrn is buggy in Wind 10 64 bit ? Anyone using it in Wind 10 _x64 ?
Tried the dll? https://hydrogenaud.io/index.php/topic,113457.0.html
THANK YOU VERY much - your searching is better than mine * my memory .
I did not try the http://ftp6.ahead.de/wnaspi32.dll .
Last night I tried the Wind 10 'compatability' for Burrrn set to W 7 .
And the Burrrn worked perfectly on 2 different burns .
"So far so good"
V for Vote
