Topic: Running CueRipper on PlayOnLinux (Read 2422 times) previous topic - next topic
I'm new to this forum, and I've noticed some people have had success installing CueRipper/CueTools on linux using Wine/PlayOnLinux.
Unfortunately I seem to be having problems since I can't seem to run CueRipper.
CueTools "seems" to be fine - I haven't tried doing anything with it, although a window does pop up, and I can configure, etc.
I am running Fedora 23 (64-bit) and 4.2.10 PlayOnLinux and 2.1.5 CueTools.
Here are the steps I am following:
1.Start PlayOnLinux.
2. Click on "Install a program" found in the left hand side pane.
3. Click "Install a non-listed program" found on the bottom.
4. Three windows pop up, and I click "Next" each time.
5. "Install a program in a new virtual drive" is highlighted, and I click "Next".
6. I type "CueRipper" for the name of the virtual drive and click "Next".
7. I check the box next to "Install some libraries" and click "Next".
8. "32 bits windows installation" is highlighted, and I click "Next".
9. I choose "POL_install_dotnet20sp" and "POL_install_vcrun2008" and click "Next".
10. A window shows "Please select the install file to run", and I click "Cancel".
11. At this point I have the CueTools zip file unzipped, and I copy the whole directory structure to /home/user/.PlayOnLinux/wineprefix/CueRipper/drive_c.
12. I click on the "Configure" button on PlayOnLinux.
13. I highlight the "CueRipper" virtual drive in the left pane.
14. I click on the "Make a new shortcut from this virtual drive" button.
15. I highlight "CueRipper.exe" from my choices ad click the "Next" button.
16. In the box that says "Please choose a shortcut name for CueRipper.exe", the name "CueRipper" already appears, and I click "Next".
17. I repeat the last three steps for "CueTools.exe".
18. I highlight "I don't want to make another shortcut" and click "Next".
19. In the main window, I highlight the "CueRIpper" shortcut, and click "run" in the left-hand panel.
20. A window with a frowny face pops up with the error:
Error in main
CUERipper crashed.
Select its shortcut and click on "Debug" in the side panel to get more details.
21. I click on "Next" to get rid of the window.
22. I highlight "CueRipper" shortcut again, and this time I click on "debug" on the left hand panel.
23. I get the following in the debugger window"
[11/23/16 18:12:40] - Running wine- CUERipper.exe (Working directory : /home/user/.PlayOnLinux/wineprefix/CueRipper/drive_c/CUETools_2.1.5)
fixme:winediag:start_process Wine Staging 1.9.12 is a testing version containing experimental patches.
fixme:winediag:start_process Please mention your exact version when filing bug reports on winehq.org.
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"configSections" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"sectionGroup" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"section" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"userSettings" in state 2
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"CUERipper.Properties.Settings" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"setting" in state 6
fixme:mscoree:ConfigFileHandler_startElement Unknown element L"value" in state 6
fixme:mscoree:parse_probing privatePath=L"plugins" not implemented
Unhandled Exception:
System.IO.FileNotFoundException: Could not load file or assembly 'System.Deployment, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
File name: 'System.Deployment, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
  at CUERipper.Program.Main () <0x1c10fb8 + 0x00057> in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.FileNotFoundException: Could not load file or assembly 'System.Deployment, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of itsFile name: 'System.Deployment, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
Any suggestions are most welcome as to what I am doing wrong.
