Topic: foobar2000 can't open files (Read 2428 times) previous topic - next topic
hello! I have been a foobar2000 for a long time. I have a little problem: if I double-click a track or if I drag-and-drop it to foobar2000 window... Nothing happens!
However I can open audio tracks using file/add files/folder... But it should be better if I was able to do it double-clicking tracks :D
I made a video: as you can see, there aren't messages in console...
Thanks in advance ;)
Re: foobar2000 can't open files
If you're running foobar2000 as admin then don't.
Are you running foobar2000 with admin rights? drag and drop won't work if you run foobar2000 with admin rights.
| QAAC ~ 192 kbps |
You might try checking security/access properties of config directory or its parent directory. Resetting access worked for me when I had this problem. Not an expert but I think it was related to "inheritance" feature of Win 7 - when folders affect each other or sth like that.
I deleted foobar2000 folders from Program files and AppData and re-installed the program. Now everything is working. Unfortunely I haven't found the issue... It could have helped developers to improve the software  :'(
Hello,
I have the same issue. I can't drag and drop, nor add files from the menu (add files/folders) from an external device-my phone. Even though the mp3 files on it have the foobar2000 file association, I can't double click/enter them and play them, it opens wmp instead. Also, when I right click on them, the standard menu doesn't appear, instead I get this: (not this: ).
I swear I've played audio files off my phone in foobar before.
Try mounting your phone as a Mass Storage device, not MTP. Hope that helps...
| QAAC ~ 192 kbps |
Ah, yes, that's what I found out to be the problem. However, I'm using a Nexus 5 (which runs Android 6.0.1) so it only supports MTP and PTP. I used to have an old Nokia phone (the aforementioned one) which I remember my computer recognized as a mass storage device. : <
Edit: And even if I use some sort of streaming app/software, it doesn't support flac files. (I think this is off-topic, though). Sorry, it seems I was under the misunderstanding I had the same problem as OP.
