Topic: ALAC PCM compare on OS X? (Read 4671 times) previous topic - next topic
I'm in the process of converting my flac to alac and need to do a PCM compare between them on a mac.
I've scoured a number of sources and the closest I've come is xAct, while it can compare flac to flac and a few others, it cannot do alac PCM checksums or compares. Besides that, I'd *prefer* to use in shell script.
Is my google-fu just weak?
Re: ALAC PCM compare on OS X?
Maybe you can convert both to WAV and compare the two WAVs?  Or, convert back to FLAC and compare FLAC-to-FLAC?
But, what's the problem?   You don't trust FLAC or ALAC to be lossless?   Or you don't trust your computer?
There is -f md5 in ffmpeg.
quick example:
orig=$(ffmpeg -i some.wav -loglevel warning -f md5 -)
echo "$orig"
flac=$(ffmpeg -i some.flac -loglevel warning -f md5 -)
echo "$flac"
[ "$orig" == "$flac" ] && echo "fine" || echo "nope"
p.s. or a oneliner:
diff <(ffmpeg -i some.wav -loglevel warning -f md5 -) <(ffmpeg -i some.flac -loglevel warning -f md5 -) && echo "fine" || echo "nope"
(probably good idea to toss "2>/dev/null" or two here and there)
I don't trust my NAS... and I'm going to address that with ZFS filer in Jan 2017 (long irrelevant story).
I've actually done a ton of conversion, then using a windows VM running foobar with bit compare found diffs.
So I do my conversion (and concurrent tagging standardization) from my mac. I have a windows VM that I bring up when needed and a few other linux servers, but not for the purpose of audio (they're actually "servers" with no head nor sound) that I could use for processing, but would prefer to check concurrently to editing of the metadata.
Thanks for the code! I think I'll just have to go down the route of trying to compile my own solution on the mac or switch to background processing the PCM cmp from a linux box and breaking up my workflow.
What do you need to compile?
Conveniently missing all of those codecs that seem to only bar distribution of the resulting binaries just to piss people off, and obviously not because people are somehow afraid of patent lawyers.
Plural? From what I can see "only" fdk-aac is missing.
Apologies for the lack of clarity in my response.
The conversion to wave of the flac & alac with a diff is a high impact over 4tb of music, but a great interim solution.
I'll end up either:
1. make shntool with the alac helper for OS X from the current code base (the problem I'm having here is finding the source as http://craz.net/ is not responding)
2. use linux attached to my NAS running shntool with alac (given I can find in usable form)
The problem I'm running into is the alac helper program available in the wild for anything other then windows (ugh).
By simply creating a symlink to alac-decoder I was able to get "shntool cmp orig.flac new.m4a" to work on linux.
I cannot find an alac helper equivalent yet for mac in either compiled+made form or source. Anyone?
How is that different from the ffmpeg solution speedwise?
