Topic: Fading out end of m4a/mp4 audio while keeping bitrate (Read 14088 times) previous topic - next topic
I have a track I got from iTunes (song.m4a). I want to cut a piece off the end and then fadeout the last 5 seconds of it.
I want to keep the original bitrate and prevent reencoding (a copy) of the non faded part.
The result can be either m4a or mp4. I am on Windows 7.
How can this be done ?
I tried ffmpeg with afade filter but the whole track got reencoded to a lower bitrate.
mp3DirectCut (FREE) can do limited editing on MP3 and AAC (MP4) files without decoding/re-encoding.
Can two AAC files be concatenated without a gap?
If so then maybe you can cut the part you want to fade, decode it, apply the fade, reencode and then tack it back on to the end.
Can you concatenate two files gaplessly?  If so then maybe you can cut the part you want to fade, decode it, apply the fade, reencode and then tack it back on to the end.
Thx Greynol. Can you tell how ?
I already did; I just don't know if it will work.
DVDdoug should be able to tell you how to cut and join with mp3directcut if you can't figure it out.
Since I don't know how to implement those steps to test, this does not help me
mp3directcut has the 'gain' option disabled with aac so cannot be used to fade out m4a/mp4/aac as far as I can tell.
Note: according to https://en.wikipedia.org/wiki/Mp3DirectCut , it requires raw aac (not in mp4). Have not tried to fade AACs myself though. (Edit: you know how to extract the stream losslessly using ffmpeg?)
How about http://aacgain.altosdesign.com/ ? Supposedly it needs an mp4 container, just to confuse.
I have not tried https://en.wikipedia.org/wiki/Mp3TrueEdit either, but no sign of aac.
mp3directcut cannot fade out aac
aacgain.altosdesign.com does replay gain not fading
but - seems like mp3trueedit can do it !!
It might not be so bad if you have to re-encode    it's my understanding that AAC was designed so that decompressing and re-compressing does very little "damage".  I assume that also applies to MP4 & M4A.  And of course, you'd have to use the same or higher bitrate when you re-compress.
(I've only used mp3DirectCut with MP3s, and only a couple of times since I'm usually editing with WAV files.)
I had the same problem with M4A files downloaded by get_iplayer. For a while I used the DVDSoft Audio Editor freeware, but I'm pretty sure that it decodes/re-encodes. And it was also slow and fiddly to use.
As the majority of my downloads from the BBC are spoken word, I decided to bite the bullet and convert them to MP3. Not ideal, but much easier to manage with MP3DirectCut.
Does the final file absolutely have to be M4A or MP4? I'm thinking that the simplest solution would be to convert to WAV, do your editing, then save in a lossless format like FLAC or ALAC.
I do edits like this all the time.  I use Reaper and render to FLAC.  I often change the name somewhat so I have a clue that the file was originally lossy.
If more editing is needed, I'll sometimes use Audacity or OcenAudio too... from within Reaper.
Be a false negative of yourself!
Re: Fading out end of m4a/mp4 audio while keeping bitrate
I wrote a couple of Windows scripts to apply fade in and fade out to AAC files using ffmpeg.
The instructions are here.
I still use them four years later when editing certain AAC files (via mp3directcut).
