Topic: Orban Loudness Meter in playback use (Read 2521 times) previous topic - next topic
Hello.
Here's one method to get the Orban Loudness Meter work for all output:
Software:
- VB-Audio Voicemeeter Banana - http://vb-audio.pagesperso-orange.fr/Voicemeeter/banana.htm
- Orban Loudnes Meter - http://www.orban.com/meter/
1. System playback settings
2. Voicemeeter settings
- signal is in Voicemeeter VAIO (VIRTUAL INPUTS)
- select your output device in slot A1  (HARDWARE OUT)
- activate A1 as output device (Voicemeeter VAIO channel)
- activate B1 as second output device (Voicemeeter VAIO channel)  (B1 is virtual device needed for Loudness Meter)
- Menu --> System Settings/Options --> check buffer settings and set samplerate if needed
3. Loudness Meter settings
- set the (input) Device to Voicemeeter Virtual ASIO (this is B1)
Finally, output is directed to Loudness Meter and to selected output device (A1)
