Topic: Change Q63 to Q64 on AAC (Apple) TVBR (Read 4490 times) previous topic - next topic
1) Change Q63 to Q64 on AAC (Apple) TVBR. Apple changed the number, I have no idea why they bother with these little things but hey, they did.
2) nu774 just added -A for refalac. Please add this string for "Apple Lossless": "qaac.exe;qaac64.exe;refalac.exe;refalac64.exe" and maybe change "QuickTime or iTunes installed or use refalac"?
2) is more important, the title is misleading now.
Have you tried 32bit version?
On 32bit version, quality steps are not changed. It's somewhat surprising, but I don't think fb2k needs to be updated.
To be honest I only tested the 64-bit but again, no big deal like you said.
Since the 1.3.8 thread was recycled, let me modify the request here, I forgot about the AAC (Apple) part:
Please add "qaac.exe;qaac64.exe;refalac.exe;refalac64.exe" for "Apple Lossless" (and maybe add refalac, working as standalone and portable, with the iTunes description on the bottom) and "qaac.exe;qaac64.exe" for "AAC (Apple)" on the "Encoder file" settings by default.
Added for the next version, thanks for the feedback.
Thanks Peter, always listening to the users!
*Just in case you didn't read this on my other post, nu774 made refalac fully compatible with qaac (-A, --alac etc., from 1.46) for this reason, so you won't have to add another setting just for refalac.
Peter, please consider removing --xlevel for MPC from the next version of foobar2000, https://www.musepack.net/index.php?pg=enc, last line.
That change makes no sense. People using old pre-SV8 mppenc benefit from the switch and for people using SV8 encoder it does absolutely nothing.
Case, thanks for that. I don't even know why I bothered, I've never used MPC other than testing and don't know it enough, I just changed the file and requested because of this: http://www.hydrogenaud.io/forums/index.php...st&p=892293
Never mind and please ignore the request.
