Dedicated touchscreen computer for music?
Reply #5 – 2015-01-20 09:46:28
A wireless network must be really poor not to be able to stream a ALAC stream. You're talking about perhaps 1 mbit/s max. plus a two second buffer in the AirPlay device to catch any small hiccups. I have a fairly shoddy wireless network (a lot of interference from dozens of neighbouring networks plus a poor router) but have never experienced a hiccup in my AirPlay. I use a 2010 MacBook Pro for AirPlay and it works fine, it's not hardware dependent, it's software dependent. If you can run a recent OS X (at least 10.7?) it will support AirPlay. Your three your old Mac will definitely support it. Why not just get some old iPad second hand (make sure it can still run iOS 7 or iOS 8 so you're guaranteed it will run Foobar Mobile for the foreseeable future) and connect it to an external DAC? Playing music is hardly taxing for a device so some three year old iPad they're selling on eBay will still be more than enough for what you want. Then connect that with a cable to your amp. I have used the 30-pin to Lightning adapter (it contains a Wolfson WM8533 DAC inside) and connected it to a 30-pin to RCA+USB cable and ran that into my amp. It charges my devices while I listen to music and it sounds great. You’ll have a very low maintenance device with a platform that will get a lot of attention from the Foobar devs for half of your budget.
