Topic: EAC setting for Yamaha Crw-F1E (Read 3762 times) previous topic - next topic
Can anyone tell me the EAC settings for a Yamaha CRW-F!E? ( Offset, secure mode?, Read command, Gap Detection method,etc. )
CRW-F1 Offset is +733.
I just tested this with Radiohead OK Computer and REM Automatic For The People.
CRW-F1 caches audio and has accurate stream. It does not support C2 error correction in the form that EAC needs it. Not many drives support C2 properly, although a few say they do!
Latest firmware (available from Yamaha website) is 1.0g.
Ruse
____________________________
Don't let the uncertainty turn you around,
Go out and make a joyful sound.
Extraction Method: Secure mode, Drive has "Accurate Stream" feature, Drive caches audio data (you must enable this option).
Drive read command: Read command D8
Read sample offset correction value: +733
Overread into Lead-In and Lead-Out: yes
CD-Text Read capable drive: yes
Write samples offset: +6
Gap detection: Detection method B, Secure.
Drive is able to write UPC/ISRC: yes.
Drive is able to write CD-Text: yes
i just tested the offset with one of the cd's on the eac list... its gave me +518 should I use that or +733 ?
