Topic: SPDIF OUT Problems (Read 3119 times) previous topic - next topic
SPDIF OUT Problems
I have a Creative X-Fi Titanium HD soundcard and I have run an optical toslink to an AVR (Anthem MRX500).  I want to bypass the soundcard DAC sound that I don't end up with a DA / AD / DA scenario.  I am running a 2.1 speaker configuration from the AVR.
I have set windows (8) to use SPDIF by default.
I have first tried running Foobar Output as DS SPDIF (Creative).  I get some crashes and some bad pops and other nasties when playing files.
So, I thought I should try WASAPI.  When I set Ouput to WASAPI SPDIF (Creative) I get the following playback error:  Unrecoverable playback error: Unsupported stream format: 44100 Hz / 24-bit / 6 channels
The AVR and card support 24 bit (which I have set in the Foobar Output options) but I've also had the same error if I set it to 16 bit.
I get this on lots of channels.  I'm puzzled (even more so at the 6 channel reference!).  Can anyone help please?
SPDIF OUT Problems
You can't have more than 2 PCM (uncompressed) audio channels when using SPDIF. You can have multi channel audio if you reencode to AC3 or DTS before the audio hits the SPDIF interface. Normal foobar2000 output when playing is (uncompressed) PCM.
If you want to have multi channel uncompressed output you will need to use a modern interface like HDMI.
If you are happy with 2 channels and you just want to make your multi channel audio play, add the Downmix channels to stereo DSP in the Foobar2000 preferences (Preferences > Playback > DSP Manager).
SPDIF OUT Problems
Hi thanks for your reply.  Does 2.1 qualify as more than 2 channels (that's all I want)?  I don't understand where the 6 channel warning is coming from - I don't even have 6 channels    The files are just mp3s.
SPDIF OUT Problems
Is this a bug in WASAPI?  I just came across this thread but the "attempt to play unsupported stream formats" does not seem to be available in Advanced/Playback/WASAPI?
SPDIF OUT Problems
OK, I selected the DSP to downmix to Stereo and some files play but, with others, I get:  Unrecoverable playback error: Invalid argument
How to I resolve this please anyone?  And why do I need to downmix in the first place (the files are 2-ch mp3s as far as I know)?
SPDIF OUT Problems
What is samplerate and number of channels of these files?
Do you have other DPSs that upmix?
SPDIF OUT Problems
Reply to question 1
Files that play are 48000 Hz. 2 ch.
Files that don't play are 44100 Hz. 2 ch.  The error is:  Unrecoverable playback error: Invalid argument
Reply to question 2
Ah - that must be the answer.  I cleared all my DSPs and then this problem went away.  Thanks for that.
SPDIF OUT Problems
Resampling with SOX has resolved the issue.  Should this lead me to conclude that my Anthem MRX500 DAC does not support 44100 Hz?  I find that hard to imagine!
SPDIF OUT Problems
Do you have a specification of the device which lists supported sample rates? I did a quick search on the internet and noticed that the official data sheet does not contain this kind of information.
SPDIF OUT Problems
Unfortunately, the specs don't list the supported same rates so I have e-mailed the manufacturer. However, the plot thickens because ASIO4All is working without up sampling in foobar. So I think this is somehow a WASAPI issue.
