Topic: Make playlist follow the current track (Read 1768 times) previous topic - next topic
Hi, new member here.
I have a playlist with 400 tracks and play order set to Random, so basically what I mean that playlist should jump through and position the playing track in the middle of it with the arrow next to it, because now I cannot follow which #number track is playing so I gotta scroll through each time searching for the arrow next to it.
So when random track starts playing the playlist should position it in the middle of the playlist.
Select "Cursor follows playback" from the Playback menu. If you use the Default User Interface, you can also double click the status bar to jump to the playing track. This works even when the playing track is in another playlist than the one you have currently selected.
Also, SHIFT + [menu] View > Show Now Playing let you jump to currently playing track, and a keyboard shortcut can be assigned to that command.
Hey all thanks for fast support. The Playback -> Cursor Follow Playback works perfect! Cheers.
