Topic: YouTube Track Manager (Read 81050 times) previous topic - next topic
Re: YouTube Track Manager
Reply #75
New Version: YouTube Track Manager 3.6
Please note the updated requirements for JScript panel & foo_youtube.
Requires JScript Panel 1.1.6.2+, foo_youtube_preconf 1.17.3+ (recommended *) and optionally playback statistics 3.02+ & m-TAGS 1.12+.
* foo_youtube_preconf 1.17.3+, or standalone foo_youtube 1.17.3+ with LAVFilters, is required to enable the nowplaying panel to show YouTube videos. If you don't want video show, any functional foo_youtube.dll can be used.
Please post discussion here.
Reply #76
New Version: YouTube Track Manager 3.7
Requirements are unchanged from post above.
Reply #77
New Version: YouTube Track Manager 3.8
Requires JScript Panel 1.1.6.2+, foo_youtube_preconf 1.18.1+ (recommended - see reply #90) and optionally playback statistics 3.02+ & m-TAGS 1.12+.
Reply #78
New Version: YouTube Track Manager 3.8.1
Requirements are as above.
Reply #79
New Version: YouTube Track Manager 3.9
Requirements are as two posts above except foo_youtube_preconf 1.18.2+ is now recommended .
Reply #80
New Version: YouTube Track Manager 3.9.1
Requirements are unchanged.
Reply #82
New Version: YouTube Track Manager 3.9.3
Requirements are unchanged from the previous post.
Reply #83
New Version: YouTube Track Manager 3.9.3.1
Requirements are unchanged from post #97.
Reply #84
New Version: YouTube Track Manager 3.9.3.2
Reply #85
^^^ Note that YouTube Track Manager 3.9.3.2 and earlier versions won't work with JScript panel v2+.
Reply #87
New Version: YouTube Track Manager 3.9.5
Requires JScript Panel 2.1.0+ and foo_youtube 2.3+
Optional components:
- A playback statistics engine or rating method is recommended for MySelect mode, e.g. foo_playcount 3.02+, JScript panel (if you use it for playback stats), a manual rating system, DAD Auto-Rating or other autorating method.
- m-TAGS 1.13+. Adds extra album management features.
Reply #90
New Version: YouTube Track Manager 3.9.5.3
This is maintenance update to fix compatibility with JScript Panel 2.2.0+. There are no new features.
Reply #91
New Version: YouTube Track Manager 4.0.0
Please post discussion here .
REQUIREMENTS:
Spider Monkey Panel 1.1.4+
foo_youtube (any working version)
Optional components
Most functionality fully works without these. But...
m-TAGS 1.13+ offers extra album management features.
A playback statistics engine (e.g. foo_playcount 3.02+) or a rating method helps MySelect mode make better choices if you use that mode.
Reply #93
New Version: YouTube Track Manager 4.1.0
REQUIREMENTS (available  here):
Spider Monkey Panel 1.2.1+
Optional components
m-TAGS 1.2+ offers extra album management features.
A playback statistics engine (e.g. foo_playcount 3.0.3+) or a rating method helps MySelect mode make better choices if you use that mode.
Reply #94
New Version: YouTube Track Manager 4.1.1
Requirements are as above .
Reply #95
New Version: YouTube Track Manager 4.1.2
Requirements are as 2 posts above .
Reply #96
New Version for JScript Panel: YouTube Track Manager 3.9.5.4
This is a maintenance update intended for users who wish to continue using a JScript Panel version. There are no new features compared with earlier 3.9.5.x versions. It's recommended that you use the latest Spider Monkey Panel version if possible, e.g. it has a newer feature set and is more actively developed.
CHANGELOG
Compatibility fix for JScript panel 2.3.x series
REQUIREMENTS
Requires JScript Panel 2.3.1+ and foo_youtube (any working version)
Reply #97
New Version: YouTube Track Manager 4.1.3
REQUIREMENTS
Requires Spider Monkey Panel 1.2.1+ and foo_youtube (any working version)
Reply #98
New requirement: your own YouTube API key. See main discussion thread for more info and how to obtain one.
