Topic: Help with getting my first Record Play Setup? (Read 6809 times) previous topic - next topic
Hi! Basically, I've purchased a dozen vinyls over the past couple years, always with the intent of getting a record player eventually. Ive looked online at the "all-in-one" record players by crosley and stuff, but apparently those are pretty crappy quality wise. Are there any decent "all-in-one" record players out there?
I would love to get a turntable with a reciever and a nice pair of speakers, but nowhere online can I find a package deal or even a guide that would direct me to any good setups.
Can anyone help me out?
Even for entry-level I would buy a separate record player/not one that's integrated into a system (like the cheap ones they used to sell at stores in the '80s.)
THIS is a really respectable entry-level turntable for a reasonable price. You will have to by a cartridge as well (and possibly have a friend/pro set it up properly for you.) This particular model has a built-in preamp (which you may bypass if desired.) All you'll need is your speakers/amp combo and you'll be ready to go.
There are other alternatives (especially if you're willing to pay more) but this is just one example that I can think of. Hope it helps.
The Loudness War is over. Now it's a hopeless occupation.
The main thing I'd look for is a magnetic cartridge.  Virtually any cartridge you buy separately will be magnetic, and most turntables that come with a cartridge will come with a magnetic cartridge so it's not a big worry, but a few cheap ones come with ceramic cartridges, and I'd avoid those.
If an all-in-one has a magnetic cartridge and line-level outputs (or tape outputs) for connection to a stereo system, it's probably OK.
I'd say the "sweet spot" is about $300 - $400 USD for a turntable, cartridge (with stylus), and a phono preamp.  If you spend much less, sound quality will suffer.  If you spend too much more quality may improve a bit, but you can spend thousands and you'll still only get analog vinyl quality.  It's not like digital where you can get super-good quality for a super-low price.  And, you hit a point where it takes a lot more money for a small improvement.
Most USB turntables come complete with a cartridge and a built-in preamp with RCA line-out connectors for direct connection to an amplifier/receiver (or line-in on a soundcard).  So you might consider a USB turntable, even if you don't plan on using the USB.
...or it might still be junk.
David.
