Topic: FDK AAC vs Opus (Read 16259 times) previous topic - next topic
FDK AAC vs Opus
Accoring to a recent HA test, Opus has beaten all other codecs at 64Kbit, however I've got very different results. I don't know how it's possible but I've just compared Opus 1.0.3 vs Fraunhofer Aac encoder at 64Kb and 48Kb, and Fraunhofer won by a huge margin.
With Fraunhofer I don't hear any discernible audio distortions at 64Kbit and minor disturbances at 48Kbit whereas with Opus the resulting audio has a very low quality. As a test I compressed some pop music songs (relatively simple audio).
ffmpeg -i source.wav -c:audio libfdk_aac -profile:a aac_he_v2 -ab 48k output.m4a (or aac_he_v1)
For opus I've used:
-c:a libopus -b:a 64k (or 48k)
Components versions:
ffmpeg version 2.1
fdk-aac-0.1.2
opus-1.0.3
FDK AAC vs Opus
Did you perform a (double) blind test?
FDK AAC vs Opus
No, I haven't, the differences in the output can be easily heard.
To give you an example, AAC at 64Kbit sounds more or less like CD audio, Opus at the same bitrate sounds like MP3 at 80Kbit/sec.
Again, maybe Opus 1.1 has improved in regard to low bitrates, but I tested 1.0.3 release.
FDK AAC vs Opus
And MP3 at 80kbps does not "sound more or less like CD audio"? That's why anecdotes are not useful and we prefer blind tests. Do you mind posting your samples, the original file and your encodes, so that we have a common ground for discussion? Maybe both encodes have artifacts, but you tend to prefer the AAC ones, but most other users don't.
FDK AAC vs Opus
You might also want to try out opus-tools instead of libopus in ffmpeg. It might not be using 20ms frames in ffmpeg.
I also briefly tested (with some 1.1 alpha/beta version) @64Kbps a while back and to me each song I tried Opus sounded slightly less annoying than fdk-aac.
@48Kbps fdk-aac sounded better. I don't have any ABX results.
FDK AAC vs Opus
birdie, I too believe AAC is better than Opus but I didn't test and prove it so I won't post anything in regard. All the test that hundreds of people have done say the contrary.
Second, why do you want to test an old version of the codec? Go test 1.1, post one or few logs and tell where you notice the difference if you want people to take you seriously.
FDK AAC vs Opus
Indeed, ffmpeg uses 10 ms frames for Opus. We do not know why they're doing this, but it's sub-optimal. You can get higher quality with 20 ms frames.
FDK AAC vs Opus
Is there already a bug logged for this at ffmpeg? I'm struggling to find anything on the ffmpeg bug list.
FDK AAC vs Opus
I tested latest ffmpeg from git  compilied with libopus v1.1-rc.  It uses 20ms frames:
D:\>ffmpeg.exe -i test.wav -c opus test.opus
D:\>opusinfo.exe test.opus
Processing file "test.opus"...
New logical stream (#1, serial: f68e8976): type opus
Encoded with Lavf55.21.102
User comments section follows...
        encoder=Lavf55.21.102
Opus stream 1:
        Pre-skip: 312
        Playback gain: 0 dB
        Channels: 2
        Original sample rate: 48000Hz
        Packet duration:   20.0ms (max),   20.0ms (avg),   20.0ms (min)
        Page duration:   1000.0ms (max),  997.1ms (avg),  120.0ms (min)
        Total data length: 3778579 bytes (overhead: 0.728%)
        Playback length: 5m:06.102s
        Average bitrate: 98.75 kb/s, w/o overhead: 98.03 kb/s
Logical stream 1 ended
FDK AAC vs Opus
I tested latest ffmpeg from git builded with libopus v1.1-rc. It uses 20ms frames...
Awesome
